PGGB upsampler: DeltaWave null analysis
TNT
Are you skeptikal because you have an adamant belief in your testing script's ability to express audible differences?
LOL... -200 dB
Thats like an atom bomb exploding standing 3 meter away.... get a grip...
tuga
Oxford, England
LOL... -200 dB
Sorry, I know nothing about bombs. Which parameter does -200dB refer to? Is it another oversimplistic mish-mash like SINAD?
fatoldgit
Practically?
Code:
sox INPUT OUTPUT rate 705600
Probably doesn't make sense to aim for better noise rejection than 16 bit.
But I guess we don't care about practicality :) Then one of those:
Code:
sox INPUT -b32 OUTPUT rate 705600
sox INPUT -b32 OUTPUT rate -v 705600
sox INPUT -b32 OUTPUT rate -s 705600
depending which tradeoffs one prefers:
Note that the latest version of sox has "-u" option which is one level above "-v"...not done any testing to see if it makes any diff.
The quality-level options are as follows. If none is chosen, the default is "-h" (high):
-q = quick
-l = low
-m = medium
-g = medium-high
-h = high
-e = extra
-v = very high
-u = ultra
On Linux at least you typically need to download the source code and compile as most distro's dont use the latest version.
Peter
theREALdotnet
The A-weighted difference between the two files in the time domain is -204dB.
That means there is still a 0.000000006% difference between them. You call that inaudible?
danadam
It looks like it gets rid of that ripple in the middle and at the end:
pkane
pkane
North-East
Painfully audible, but only to Rob Watts from Chord, who claims to hear noise floor modulation down at -300dB :eek:
pkane
pkane
North-East
-q = quick
-l = low
-m = medium
-g = medium-high
-h = high
-e = extra
-v = very high
-u = ultra
Peter
When I get a few minutes, I'll give the -u option a try to see if it makes a substantial difference.
GXAlan
So, DeltaWave upsample result is closer to PGGB than SoX with -v option, but overall, the difference is still completely inaudible and well below 23 bits.
What you mean to say is
“My ASR-tested, ultra-precision $500 upsampler software based upon the field-proven, instrumentation-grade DeltaWave technology provides results nearly identical to the twice as expensive PGGB but at world-class speed and convenience. My hand-selected algorithms provide superior matching to PGGB’s maximum quality setting than even the open source SoX upsampling tool.”
pkane
pkane
North-East
I was going to charge $900 for it, actually ;)
GXAlan
$900 with $400 coupon code :)
Then you can say “performs as well as software twice the price”
fatoldgit
Ouch, the steep (-s) conversion clipped and that's why the noise floor was elevated. After fixing that, the noise floor is now comparable to the non-steep version (and the same applies if you use it together with -v or -u):
I may be wrong... but "-s" isnt a quality setting... so without a quality setting specified your quality will default to "-h" (and the related combo settings it drags in, as per my original post above)
"-s" relates to Bandwidth (Audio Passband Percentage):
-s = -3 dB 99% (steep filter)
-b <74 .. 99.7> = -3 dB percentage
-B <53 .. 99.5> = 0 dB percentage
I would imagine you need to use a quality setting and "-s" in combo?. I theory "-u -s" gets you the good stuff from "-u" (as per my original post above) plus a steeper filter.
Maybe play around with that?
Also in theory "-b 99.7" is an even steeper passband!!!
Peter
fatoldgit
Yes, that's what I meant by "use it (the -s) together with -v or -u."
cool.
Hate to think you spend time doing the analysis to find the wrong params were in play.
I am really enjoying this thread... like many I use sox over other options (although I have play around with camilla) so its great to have empirical evidence that sox is very very good....and its free!!!.
Peter
PS. might want to change the graphic to read "-u -s"... or are you saying that "-s" buggers up anything it touches (maybe overrides all other options when used)?
danadam
I'm not sure I understand. The gray graph is the result of "rate -s" (implied "-h") conversion. Now that I fixed the clipping in the generated files, its noise floor is more or less the same as the noise floor of the magenta graph, i.e. "rate" (implied "-h") conversion. So as the documentation says, "-s" only affects the passband.
If I plotted the result of "rate -u -s" conversion, it would be more or less like the green graph, only with wider passband.
manisandher
Royal Leamington Spa, UK
SoX -u flag produced an even better match to PGGB. The difference between PGGB and SoX is now well below -200dB, unweighted (rms of -207dBFS and -209dBA)
Is it clear that PGGB and SoX are more accurate than DeltaWave?
(Not that it matters in the least bit for all practical purposes. Purely out of interest...)
Mani.
