Pi3+D70+Atom+HD650
laidick
I am too happy with this setup in bedroom while not allowed to listen my living room.
Can anything else be better ?
Pi3B+ with Volumio installed as streamer
USB to Topping D70
XLR to RCA to JDS Atom
6.5mm to HD650
I think I am done for now.
Thanks ASR.
laidick
laidick
Great set up. Enjoy!
Just the little point I don't understand. Why not just using RCA ?
I have both XLR and RCA, just experiencing which one is better.
D70 XLR out measurement seems a hair better than RCA. But my ear is not able to differentiate them yet (and ever...)
VintageFlanker
Paris
Both are quite undistinguishable according to @amirm review.
Still, even if XLR (balanced) was really that better: XLR to RCA adapter doesn't transmit a balanced connection at all. Not sure about that, but it could even get worse.
I would go for a simple RCA cable if was you.:)
laidick
laidick
Yes that's correct, let me switch it back and see if anything changes :)
I don't use adapter, I ordered a pair of canare cable from ghentaudio, one side XLR and other side RCA.
laidick
laidick
By the way, I also ordered SMSL500 from taobao with 11/11 discount, just about $276 USD.
Would place that in living room in case I need it :)
Berwhale
Are you planning to put any cooling and a case on the Pi? My understanding is it can get a little warm and start throttling the CPU - I don't know if this much of a concern when running something like Volumio - I stuck my Pi 4B in a case with heatsinks and a fan anyway.
laidick
laidick
I ordered a pi4b on the way with Argon One case, which is aluminum with heatsink , because I heard the heat problem on 4B.
But I am currently use 3B, which is slower, but definitely no heat issue at all . Just a bit warm when I touch it. Naked seems fine too :)
I am afraid fan would generate noise in my signal chain, so I would avoid using any fan is possible.
laidick
laidick
Why haven't you removed the plastic foil over the display ?
Hahaha , good spot. That was put in living room I just normally keep those plastic to protect the little screen from being scratch. I don't read it all the time anyway.
Berwhale
The 4010 fan in the GeekPi case I bought is audible on slow (and very audible on high) with the Pi on my desk. I know that I won't be audible when installed in my lounge. If I do get bothered by it, I will look into quieter fans like the Noctua I put in my Dell managed switch (to replace a Delta fan with a supersonic whine)...
https://www.amazon.co.uk/dp/B071W6JZV8/ref=pe_3187911_189395841_TE_dp_1
I hadn't really considered the potential for electrical noise from the fan. However, a quick scan of DIYAudio does indicate that this can be an issue. I would be interest to hear if anyone has encountered and dealt with this on the Pi4.
*edit* There is a useful comparison of cooling and acoustic performance of various 40mm fans here: https://www.martinrowan.co.uk/2019/09/raspberry-pi-4-40mm-fan-comparison/
It's no surprise to me that the Noctua comes out quietest, but you do pay for the privilege - I have 4 Noctua fans and one of their controllers in my PC; this added almost £100 to the build cost.
laidick
laidick
That's insanely expensive to match the price of a pi4 this case.... May be you want to have a look on argon website ?
lopchu
Nice, thanks for sharing!
I currently have
Pi3B with Volumio installed as streamer and a 128GB micro sd card with flac files
USB to Behringer UCA222
RCA to NAD3020 (stereo amp)
6.5mm to HD650
I am planning to exchange the NAD3020 with a proper headphone amp like the Atom. And I have read great things about Pi dac hats utilising the I2S connection.
Daverz
I'd want more space for music.
I'd also put the Pi in a case. The standard plastic one is fine, and I suggest black so the LEDs aren't bothersome in a dark room. I don't think it needs a heatsink.
lopchu
Oh, nice. Thanks for the hint. Was looking at the HifiBerry DAC already and I am pleased to see it measured well.
laidick
laidick
I use a blutak to hide the LED
laidick
laidick
There is another on called nanosound DAC which is great too. You may want to have a look.
