Placement help in restricted room? (new speakers?)
mlid49
Hello everyone,
I'm pretty restricted in my placement options atm. (excuse the terrible diagram) I'm unable place the speakers in the bottom half of the room, (it's there for reference only). I was suggested that the right side of the 190" wall would be my best bet (speakers will be firing towards the long end of the room). Speakers are rear-ported with rear tweeters.
The problem is that I've been experiencing channel imbalance in this room (the sound definitely shifts right) I'm wondering if this is an issue with placing one speaker alongside a wall (*walkout window), with no wall of any sort besides the other?
So I've been wondering if there's something I could get that eliminates some potential room factors? (Active speakers? DSP?)
I also have some questions regarding my room itself,
1. Should I look towards covering the mirrors at the back with a blanket or something? (was told it won't be an issue with how faraway they are)
2. What should I do about the *walkout window? I’m told the curtains I have now won’t do much to alleviate its effects. Thicker curtain?
Thanks for your time.
M
mlid49
Bump. I was wondering how I should go about accounting for room dimension? (In cubic)
Would accounting for the “l” and “_” parts of the room then adding them be correct?
3.8m (150”) x 3.5m (140”) x 2.2m (86” [ceiling height]) + 4.8m (190”) x 3.5m (140”) x 2.2m (86”) = 66m3?
I rounded down, and sorry for switching between metric/imperial. Though, does knowing this measurement really mean anything considering the odd shape/limited placement for my speakers?
(Would still appreciate any help for my original questions as well if anyones willing)
Thanks.
RayDunzl
Central Scrutinizer
Riverview FL
Sorry, looked before, figured someone else would give it a shot.
Room symmetry is better, you don't have much chance of it.
Either deaden a sidewall or try erecting a reflector on the side without.
Maybe just be happy with casual listening till a better place comes along.
I might move the speakers for a nearfield setup if I wanted to just immerse in a soundfield, move them back to wherever afterwards.
As for the image shifting to one side, pull the speaker that sounds farther away closer to you an inch or two at a time. That may help. It will adjust the timing of the wave arrival.
M
mlid49
Thanks for the reply.
Are you suggesting absorption on the sidewall (window) close to the speaker? Would that solve the imaging issues? Also, I could move the speakers in a bit so that sidewall becomes less of an issue, but that would move my listening spot right beside that little 45” wall, no go?
Memoryerror
Can you swap the speakers/listening area with either the gym equipment or the piano?
RayDunzl
Central Scrutinizer
Riverview FL
You are in the best position to experiment, since you're there.
I've had a sidewall/no wall condition before, but it didn't present a noticeable problem, my speakers being dipoles.
M
mlid49
No, at least not at the moment. I’ve been curious as to whether or not that‘d be worth it, but the mirror wall is pretty much the same length as the current front wall I’m placing it at, just without the sidewall problem/first reflection wall being closer to me. 150” wall limits rear wall distance if I ever switched speakers. Of course, please correct me if I’m wrong in my assumptions.
M
mlid49
Bump. I was wondering how I should go about accounting for room dimension (for speakers that may demand it)? (In cubic)
Thanks.
Still wondering about this, also curious if I could somehow capitalize on my current speaker’s rear tweeters?
