Please advise on a DAC+amp combo, and a headphone with a warm, relaxed sound
Molasses
First of all, I'd just like to thank Asmir, Wolf, and all the other contributors on this forum -- I've learned a lot from all of you.
A week ago I just wanted to find a nice pair of headphones on Amazon that I would drive from my laptop. And now thanks to this forum I've somehow fallen down an audiophile rabbit hole....and the only way to return to sanity is to obtain the perfect DAC, amp, headphone combination (for my budget range).
Combination 1
Topping D10
JDS Atom
HD6XX
Combination 2
Soncoz LA-QXD1
Geshelli Archel 2.5 Pro
HD6XX
Would combination 2 sound noticeably better?
Do balance interconnects make much difference?
Is the HD6XX the right headphone for me?
Also, would it be possible for Amir and Wolf to test the SINAD etc of DAC + amp combinations? (edit: this question was already previously answered https://www.audiosciencereview.com/...inad-numbers-of-separate-dac-amp-combos.5374/ )
Thanks everyone
Wombat
Australia
This site has lots of reviews for your perusal. What it can't do is match your personal preferences if they are not for transparent reproduction.
:rolleyes:
Wombat
Australia
Veri
HD6XX
The HD6XX does not need that much power, so balanced is a little overkill, things will get loud quite quickly. Still, if you get more demanding headphones later you are already set. Soncoz+Geshelli is quite future proof if you can afford them.
But on a budget Atom with a nice DAC will definitely suffice. Also look into modi3+magni-heresy it's a sexy stack in black color :)
Wombat
Australia
How do they 'synergise', whatever that means?
M
Molasses
Thank you, Veri. I think I'll get the Soncoz+Geshelli to satisfy my newly discovered audiophile neurosis
Bear123
Mix matching poorly designed, colored gear to attempt to arrive at your personal preference of colored sound is the typical "audiophool" pursuit leading to huge sums of money being spent on lousy, expensive gear. Just buy inexpensive, high quality, neutral gear, and add a little eq or tone controls to adjust to taste.
M
Molasses
I have no idea what people mean by synergize. I saw people suggesting that certain pieces of equipment work better with other pieces of equipment and I wondered if that was something that could actually be measured
M
Molasses
I selected the DAC and amps that had the best SINAD and other measurements at their price range, I intended for the headphones to provide the 'flavour'. I read that the HD6XXX had the profile I'm looking for, but I haven't heard them, and I can't go to an audio store and try things out due to lockdown, so I thought I'd ask the ASR hive mind for help
Wombat
Australia
In terms of one piece of equipment overcoming the shortcomings of another it is not likely for the usual hifi components. Better to buy 'transparent' devices and EQ to your liking.
That is not to say another hasn't combined non-transparent components to their liking but what are the chances of you liking them similarly - particularly headphones?
The best ones are the ones you like after trying them for yourself. ;)
Veri
I selected the DAC and amps that had the best SINAD and other measurements at their price range, I intended for the headphones to provide the 'flavour'. I read that the HD6XX had the profile I'm looking for, but I haven't heard them, and I can't go to an audio store and try things out due to lockdown, so I thought I'd ask the ASR hive mind for help
HD6XX is a great start to hi-fi audio. I never got rid of my HD650, it's a keeper :)
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
I got the HD6xxx, as my first set of headphones...always been a speaker guy (still am really), and I like them a lot. I don't listen to headphones much, but when I do I'm not thinking about what I'm missing, and don't feel like I need anything else.
I also got the Etymotic er4sr, and find them remarkable.
I use the JDS Atom usually...but I don't care about visual synergies, and just tuck stuff out of sight as much as possible.
raindance
I have the MassDrop HE4XX and I drive them with a Channel Islands Audio amp and a Schiit Loki Mini for tone controls. I find these headphones warmer than any Sennheisers even without tone control intervention.
M
Molasses
Thank you for all the feedback, guys. I really appreciate it
ZolaIII
LOXJIE D10 DAC + Schiit Heresy Magni 3+ or Atom Amp. LOXJIE is just 90$ this day's on Ali, you can find review measurements hire.
solderdude
The Neitherlands
HD650 never struck me as having a 'warm, relaxed, fun sound'
Instead I would call it 'warmish' neutral sound.
Not particularly 'relaxed' and 'fun'.
Of course the sound could be 'fun' and 'relaxing' to people.
Veri
Maybe not as fun as it is relaxing, for me it's definitely a kick back and relax headphone. I do EQ in some missing sub-bass though.
A800
Tubes...
