please help me bettter understand amplifier measurments
wadec22
why do all amplifier measurements show a downward sloping line until they clip? often the distortion at 1mw is significantly higher than close to 1w. I have a tough time wrapping my head around it, as I wouldn't think distortion would actually set in, until the amplifier was boosting the signal beyond it's means.
as a follow up, with headphones that are extremely sensitive - 108db/mw and 25 ohm - does that make the overall SINAD score of an amplifier moot to me? Should I only be concerned about 1mw and below - as I know I'm never listening at 108db!
thanks for any insight guys. I love learning about this stuff!
DonH56
Monument, CO
Most all analyzers actually plot the signal-to-noise-and-distortion (SINAD) ratio, not just THD. It is hard to isolate the actual distortion from the noise at very low power levels so noise and distortion get lumped together. Noise is roughly constant, so as the signal level (power output) drops, the SINAD decreases -- same noise, smaller signal, so the plots rise because noise is included and the ratio of signal to noise goes down. Again, smaller signal, same noise, so signal (down) to noise (same) means the overall curve goes up at low power. Similarly at higher power the noise becomes less a fraction of the overall measurement and the curves flatten out because noise and distortion are roughly the same for a bit. Sometimes you'll see a curve flatten for a while until the signal significantly exceeds the noise and distortion starts to dominate, then at high power it is all distortion as the amplifier begins to clip and the curve rockets up.
HTH - Don
RayDunzl
Central Scrutinizer
Riverview FL
The same thing happens measuring speakers in-room.
At low SPL, measured "distortion" is high.
As the level of the speakers increase the measured distortion decreases.
At some level, actual distortion exceeds the noise floor, and the measured distortion rises.
For my main speakers the reversal in the direction of the distortion measurement occurs at about 90dB SPL in room.
See https://www.audiosciencereview.com/...-and-dac-measurements.5734/page-3#post-128094
RayDunzl
Central Scrutinizer
Riverview FL
Seems to me the answer might be "yes" to the second part.
Small numbers there:
wadec22
wadec22
HTH - Don
This was a damn good explanation, thanks!
SplitTime
Maybe I’m missing something with the “overall” SINAD score... but several devices have SINAD plots with different noise levels. As a result the noise dominated portion of the plot can be lower for some devices than others... at a given power level. So, I think (??) the plots are still useful for giving you an indication of which devices would still sound better (e.g. have less noise at your desired power level).
RayDunzl
Central Scrutinizer
Riverview FL
They don't.
2, 4, and 8 ohms load top to bottom. Aug 10, 2000
DonH56
Monument, CO
They don't.
Actually, I'd bet the downward slope at the left is noise-dominated, then distortion kicks in around the 1 W level (4/8 ohm loads), then we see normal'ish distortion changing with bias and such until clipping. I suspect this is a balanced amplifier design as they tend to have that sort of "humped" distortion plot, and furthermore guess it has very high SNR (and perhaps relatively low feedback) given the low point at which it crosses from noise to distortion in the plots.
RayDunzl
Central Scrutinizer
Riverview FL
Noise dominated on left - agree
Bias - is (theoretically) Class A, with (maybe) seven increasing levels - they call them "plateaus". On mine, next newer model (still old now), from the wall, I see levels of 100W (idle), 150W, 250W,, 400W (more or less, and stable give or take a watt or three of music power) and not ventured (measured) above that point, though I have popped the 15A breaker (two amps plus everything else on one outlet). Higher signal level "trips" higher bias levels, if no other "trip' in 30 seconds or so, it backs down to a lower bias level.
Balanced - yes, differential output, no single ended input
Very high SNR - 118dB SNR A-weighted quoted
Feedback - unknown
For the posted graph - https://www.stereophile.com/content...nced-350mc-monoblock-amplifier-specifications
Mine are a slightly dehanced greener version - Krell FPB 350 mcx - specs at the very end
