Polk R500 Tower Speaker measurements and review by Erin's Audio Corner
thewas
Video review:
Written review with more data and subjective evaluation:
norman bates
Iowa, US
hmmmmmmmm.
I think a tmm is a hard sell nowadays, especially dual 5.25" drivers, at least compared to their less expensive, smaller r200 (a 6.5" 2-way), or even their r600 (tmm with 2 x 6.5").
On axis, the r500 looks good.
Penelinfi
Widening upper mid/low treble plus IMD at 1k may give "airy kids" but slight smearing at the same time. At least when turned up.
Seems fine otherwise.
Beave
That dip around 150-160Hz looks to be a significant cabinet resonance (right?). I'm surprised Erin didn't hear anything amiss there. Otherwise, looks pretty good for a not-crazy-expensive tower.
norman bates
Iowa, US
"but there is also a strong resonance in the cabinet due to the height and that actually brings down the mid-base area" (@6:01+)
"you can see that I highlighted this cabinet resonance right here around 160 170 Herz or so" (@7:07+)
Beave
Ha, thanks. Stupid me, I only read his written account. I didn't watch his video.
kemmler3D
San Francisco
All in all looks fairly decent for the money, can be had for around $1100/pr if you find a refurb.
thewas
thewas
The resonance around 150 Hz can be found in many floorstanders, being due the standing wave inside the cabinet in the long dimension, some counteract it with extra padding or a Helmholtz resonator in the middle or separating the internal volume to the woofers.
norman bates
Iowa, US
perhaps it is so "column" like that the dip is measurable.
10.1" x 13.7" x 41.1"
or
255mm x 348mm x 1044mm
maybe the square area versus length brings out the resonance....
or when 2nd longest dimension is only 1/3 or the longest dimension, maybe.
I always try for 1 : 1.618 ratios.
