Portable amp/DAC with Airplay. Why this does not exist?
Fofocho
I like to listen music wireless on my headphones. I use an iPhone so I am limited to AAC over Bluetooth. But even with an android and superior Bluetooth codecs, it would be lossy
Why isn’t there any portable amp/dac with Airplay? That would be lossless (16/44,1 on Airplay and 24/48 on Airplay 2)
Jimbob54
I guess because both devices need to be on the same wifi network. Not sure if it works tethering the receiving device to ones phone and setting up a mini network- but I guess Apple always figured it was for home devices. Plus limited appetite for 3rd party manufs. to pay for licensing etc using it would entail.
Pure guesswork on my part but I think Bluetooth has always been seen as the mobile solution for connecting devices on the fly.
F
Fofocho
It is weird. Even Apple on their Airpds Max use Bluetooth only and not airplay, so you get a $600 Apple headphones that cannot benefit from Apple Lossless music
However in my receiver I can enjoy Airplay using 2 brands (Tidal and Marantz) that have nothing to do with Apple
Vincent Kars
The moment you use protocols like Airplay, DLNA, etc, you need WiFi for a wireless connection. WiFi consumes substantial more power than Bluetooth. So it is either a big battery adding (to much) weight to your headphone or a small battery hence a short battery life.
Really? They do have to buy a license from Apple.
F
Fofocho
Of course they have to buy a license, that was not the point. The point is that Apple, that does not need to buy any license, do not offer Airplay on their expensive AirPods Max
voodooless
Netherlands
Apple rules that AAC is virtually indistinguishable from lossless, therefore there is no need to deliver lossless audio the the AirPod Max.
F
Fofocho
So Apple has decided that lossless is indistinguishable from AAC but at the same time they have included hi-res music on their platform?
voodooless
Netherlands
Yes, they think that’s a nice gesture for the people that would like to have it anyway ;)
F
Fofocho
The problem with AAC is not the resolution, which is 16/44,1, it is the bitrate of 256kbps, which is not even CD quality (1411 kbps). Hi-res is even above. But Apple says 256kbps is identical to CD… ok
voodooless
Netherlands
That’s not how it works. According to your logic, Flac would also be lower quality, because the bitrate is also lower than Redbook. And actually AAC can encode and decode 24 bit audio just fine. In fact Apple uses 24-bit masters for quite a substantial part of their library for AAC.
For most people, that’s definitely the case:
The audibility of high-res may even be more disputed.
F
Fofocho
Putting hi-res aside, you mean that bitrate does not matter? Apple claims to be super efficient with AAC compression, but even that I think that bitrate matters. I can hear a clear difference between Spotify and Tidal, for example
voodooless
Netherlands
TonyJZX
apple tends to say a lot of shit... just like uncle paul mcgowan
and apple sometimes needs the entire force of the EU to come down on them to see sense
apple also likes to drip feed stuff to you so you'll continue to buy airpod max iv one day
F
Fofocho
Anyway, going back to the topic (Airplay). A quick test: I am sending Apple Music via Bluetooth to my Marantz receiver and I am doing the same with Airplay. Airplay sounds so much better
cbass
Another likely reason that AirPlay is not supported is because you would, eg, have to connect your headphones to the local WiFi network before you could use them, which is “fine” for your home LAN. But consider connecting to someone else’s network, which introduces scenarios like a malicious user on the network being able to interrupt your listening session.
Direct connection by WiFi could be possible, but this forces your iDevice to use its WiFi radio to be your headphones’ “access point” with all other traffic needing to go via cellular data, and let‘s not even consider the scenarios of Macs and iPads that don’t have cellular network support at all! This is why Bluetooth exists in the first place, for point-to-point pairing with relatively low friction.
There are numerous trade-offs to be made here aside from pure sound quality.
F
Fofocho
Yes I see that point. Airplay makes sense only at home, but many devices include Airplay as an additional option to Bluetooth and license is not that expensive, the WiiM Mini has Airplay
Chrispy
PNW
Even a slight level difference tilted towards airplay can make it seem that way, tho. Level matched and blind would be more the way to test to see if you can distinguish....
voodooless
Netherlands
I also think most Marantz AVRs only support SBC over Bluetooth, which isn’t the best codec anyway.
F
Fofocho
Levels are matched in the receiver, even I have tested with a decibel app. Also, when I wire my BTR5 to the iPhone, the sound changes dramatically, much more detail than in Bluetooth. Here I am not comparing Bluetooth with Airplay but with wired connection. I cannot buy that Bluetooth is indistinguishable
Chrispy
PNW
Output level is one thing, input another. Accuracy with an spl meter could be iffy too. Bluetooth codecs can be different, tho as mentioned.
