Power conditioner for Euro plugs.
Charles_b
Hello guys,
I was interested in purchasing the Tacima 6 way power conditioner and the Tacima parallel mains conditioner (linked below). They have got a lot of positive review and don't break the bank (I don't want/have not got 1000's to spend on some of the higher end power conditioners.)
My problem really is that as I live in Norway (previously the UK), the wall outlets/electrical plugs are the 2 pin European kind and not the 3 pin UK variety.
Tacima don't make these two things for the European type plug market, therefore, is there a decent, equally reasonably priced alternative that I could use or could I could I simply buy the UK versions and use several uk>euro plug adapters ( grits teeth)?
Many thanks,
Charles
https://www.amazon.co.uk/gp/product...FADW0PO&psc=1&ref_=d6k_applink_bb_marketplace
Https://www.amazon.co.uk/gp/product...L5A1OLE&psc=1&ref_=d6k_applink_bb_marketplace
Speedskater
Cleveland, Ohio USA
All power conditioners should be safety approved for your location.
Why do you think that you need any power conditioner?
C
Charles_b
I have invested in a decent amp, preamp, Dac and speakers. I have also bought some decent(ish) speaker cables (without breaking the bank). I was wondering if there were any other "tweeks" that I could do in order to maximise sound quality. I also saw this video on YouTube posted by a British audiophile where he mentions the power conditioner;
Also, I live on a hill so lightning strikes are quite common here-they have already taken out the washing machine amongst other things. As a euro plug doesn't have an inbuilt fuse, I was looking for a power strip with a built in fuse/surge protection.
Thanks,
Charles
RayDunzl
Central Scrutinizer
Riverview FL
Or, cut the existing plug off and wire a replacement;
https://www.110220volts.com/cee-7-7-plug.html
Unless you have an identifiable problem that the device will address, I wouldn't look for any audible improvements.
M00ndancer
Sweden
