- Thread Starter
- #21
Ah, the link you posted works with Chrome!
Hi Amir
Please watch and let me know your thoughts. Any critisicms.
But something magical happens when you attach a $4,000 cable to the end 12/2 Romex
I watched and didn't know if A or B was the better cable because I skipped to about 3 minutes into the video. There is no doubt that B sounded significantly better.Please watch and let me know your thoughts. Any critisicms.
Personally I find it embarrassing to be from the same country as this fellow. Even if there was any in all this cable stuff does anybody seriously believe that swapping out a couple of cable will do anything when your home wiring is unchanged, the line from your home to the sub-station unchanged and the wiring within the component unchanged? I am almost surprised nobody has built an audiophile turbo-generator and started selling audiophile grade electricity at $1000 a KWhr as they would probably find lunatics to lap it up.
Considering diminishing returns, one would expect a big jump in SQ with a $50 or $75 cable, but no, apparently you have to spend thousands to enjoy the effect.
....Food for thought for Furutech, Audioquest, and others: Outside wire for audiophiles
They definitely sounded different to me. So I downloaded the video and extracted the track in my audio edior. Here is the outcome:Hi Amir
As you see in the Left channel on top, the level suddenly drops with "the other cable." But nothing like that happens in the other channel.
Those frequencies are in prime audible range. Imagine the damage if they were to make it through to the output. Wouldn't it be better to increase the frequency to something well above the audible range? The transformer could also be much smaller then.This is what is the currents in the secondary of a power transformer looks like.
The primary is the same but of course lower in current.
No audio, just short pulses to replenish the smoothing caps.
Frequency spectrum of these pulses below.
Yeh, it does look that way. Very strange transformation. Hard to imagine it being due to simple mistakes like a loose jack and such.Track B bottom right looks more squashed.
I bought one a while ago to test.....How about this review of the Furutech advanced power wall socket with Rhodium plating?
I like the way he hooks up that fancy outlet to 50 cent construction back box and of course, ordinary drywall. Wonder why they don't sell the backbox and new drywall to go with it.How about this video of the Furutech advanced power wall socket with Nano Crystal Formula? You can't plug an expensive power cable into a regular socket that would be heresy, wouldn't it?
