Power for toppings D50s
PETERPAN
Hello All
I bought a Toppings D50s, but did not know I needed an external DC power source. Please suggest one I can buy on AMAZON. Thank you.
Eetu
Helsinki
You can connect the supplied power cable to your PC's USB port or use a regular smartphone charger. No need to get anything fancier than that.
P
PETERPAN
Thanks for your suggestion. I am asking specifically for a stand alone power supply, any such sugestions very much welcomed.
Glasvegas
Topping sell a matching power supply
https://www.amazon.co.uk/TOPPING-Linear-Supply-110V-240V-Black/dp/B07VPP255D
I use this to this power bank for a CCA and a Topping D50
https://www.amazon.co.uk/dp/B00VJSGT2A/ref=pe_3187911_185740111_TE_item
Mostly for convenience.
Not sure if either would affect sound quality. I sure other members will have an opinion on that.
P
PETERPAN
Great. Nice to know they do the P50. AMAZON has a very long wait for that. Still open to more sugestions.
raistlin65
Grand Rapids, MI
