Power Supply for Topping E30
marco80
Hi there,
I finally got my Topping E30 today and noticed that it doesn't include a power supply. Now if I remember correctly, the "linear-power" supply sounds better is a myth or at least not noticeable compared to a regular supply.
Also while it required (5V/1A), as it's USB I can just plug it into any USB charger like from an iPad or iPhone or some USB hub and it will regulate the power by itself. Is that correct or do I need a specific 5V/1A supply?
Thanks!
Marco
3125b
Germany
I powered mine from a USB3 socket (USB3 has a higher current capability than USB2) from my mainboard and from a phone charger - both work absolutely fine. No need to spend money on an additional power supply.
M
marco80
Actually my raspberry pi3b does a great job powering the DAC too as far as I can tell :)
DeepFried
UK England
i'm using an amazon brand 2 socket USB wall charger with my E30 with no complaints. its listed as 'AmazonBasics Dual-Port USB Wall Charger (2.4 Amp) - Black'
confucius_zero
Would a usb wall charger offer the same kind of performance as a power bank?
Jimbob54
Depends on the wall charger and the power bank, surely? Power banks arent necessarily "clean", are they? And a DAC should have (this does)noise filters anyway
digitalfrost
Palatinate, Germany
Glasvegas
No, I’m afraid you can only charge it OR supply power to the DAC.
There may be other power banks which can do both at the same time, but you’ll have to search. I’m sure they exist.
NDC
Sydney, Australia
I use a little Apple iPhone wall charger and it works excellently.
zacster
Would I be able to use an Anker 13000mAh phone charger into a RPi 3B, and then the USB out from the RPi to power the E30, and also a separate USB cable to feed the bits? I currently use this charger to power my RPi/Allo Boss combo without any problem, but the Boss HAT takes power directly through the pins. The charger will last almost the entire day powering this way.
Or would I be better off using my iFi iPower 5v charger? When I've used that with my RPi/Boss I found that it ruined the sound. (I re-read the post directly above, maybe it does ruin the sound) I guess that'll likely still be my answer, but I've also seen comments that the E30 isn't picky about power supplies.
NDC
Sydney, Australia
Assuming the power supply is engineered correctly, and has the right specifications, it shouldn’t affect the sound at all. I imagine you wouldn’t be able to differentiate the power supplies in a blind test, so go with whatever is best value.
You could probably power the E30 from the anker as well as the RPi if it has 2 ports. Then just run the USB cable out of the RPi to E30 for digital out.
tades
Grenoble
From my own experience, Ifi PS introduces even more glare than standard Phone PSU. I sent it back.
I would suspect that a battery PS has a too high dynamic impedance and would rather go for a powerfull non switching PSU.
zacster
So far I've powered it from a RPi USB port, where the RPi was powered by the Anker battery, and right now I'm listening to it plugged into my iMac for both source and power. I've only had it for a few hours now and haven't had much of a chance to play with it. Sounds good though.
raif71
Glad to hear it as I'm finding it hard to find a power supply board with exactly usb 5V/1A... all I could find was 5V/2.xA
