Powered monitors without AD conversion
AudioStudies
Does anyone know of any powered monitors that do not have AD conversion? I am aware of the Focals and Gibsons, but would like to learn of more, particularly highly rated ones. It seems a bit odd to me to research DACs well, buy a highly rated DAC, and then feed the signal into powered monitors with AD that have internal DACs that may be much worse than a high quality outboard DAC. Does anyone else worry about this, or do I just worry too much? As great a thing as studio monitors are, it is a bit frustrating that it is so difficult for any reviewers to test their internals. Also curious if there are some of you who own Gibsons, like I do, and enjoy the look that was designed to look similar to a guitar.
Matias
São Paulo, Brazil
All Neumann monitors except the KH 80 DSP.
A
AudioStudies
The SMART-enabled Genelec monitors accept digital input that does not involve an AD-step. Inputting analog to those monitors involve an AD-step.
Thanks, but I am not looking to input digital to the powered monitor, just hoping to find something with amps and drivers that will amplify my analog signal from my DAC. Something without ADC and then the subsequent DAC in so many of the modern studio monitors.
Trell
Ah, I misunderstood. Then there are Genelec monitors for that as well, some reviewed on ASR.
https://www.genelec.com/active-2-way-studio-monitors
A
AudioStudies
Why though? Aren't those A-D stages basically transparent anyway?
Well that is the $64,000 question. And a difficult thing for reviewers to determine both the transparency of the ADC and subsequent DAC prior to the signal reaching the speaker drivers.
RobL
Depends on the converter how much, but noise floor accumulates with each pass through AD-DA. I think in a blind test I read about that with 3 conversions most couldn’t tell, after 5 conversions most heard the degradation and after 10 conversions it was obvious.
Chrispy
PNW
Why would I trust a reviewer's "determination" in the first place for "transparency" (audibly I assume) of such?
A
AudioStudies
I was thinking more along the lines of ASR-type reviews, where there are some well thought out objective measurements, not solely listening tests.
Chrispy
PNW
Solely listening tests other than my own I find generally useless but thought that's where you were going :). Personally I can't imagine not wanting digital active crossovers if I'm going the "monitor" route.
dfuller
Neumann (save for the KH80), Focal (their entire line), ATC (their entire active line, passive is well... passive), Genelec 1031 and earlier versions of the 1032, Dynaudio BM15A (though this doesn't exactly perform amazingly wrt directivity what with no waveguide and a 10" midwoofer) and BM6A...
dfuller
How is an analog crossover "active"?
Simple, it's before the amps but not done via DSP. Instead it's a mix of active (i.e. done using op-amps) and passive filters done at line level.
So, do you think I am worried for no reason?
Yes and no. If you care about latency, DSP is never a good solution because you inevitably add 5+ms of latency between AD-DSP-DA. Otherwise, little concern to speak of.
