Powered speakers + multichannel AVR w/DSP...how would it work?
krabapple
I'm intrigued by the excellent performance of powered monitors like Genelecs. But I am committed to multichannel playback (5.2 currently) and I am used to the convenience of 'full feature' AVRs like the Denon line, that has automatic speaker setting, room EQ DSP (further tweakable using an app) , a range of upmixers, a variety of digital input ports, and ability to recognize and decode a wide range of audio formats.
How would one integrate a set of powered speakers into such a system?
voodooless
Netherlands
Pre-out AVR => speaker
Should to the trick.. you might next RCA to XLR cable.
sigbergaudio
Norway
It's no different than connecting a power amplifier to the AVR, a very common scenario.
So you need an AVR with preout support for the channels where you intend to go active.
K
krabapple
Yes, the multichannel pre-outs on both my Denons are RCA.
sigbergaudio
Norway
Fahzz
Outside Providence
So are the inputs in most active speakers switchable from a remote controller i.e. RCA input from AVR and SPDF or USB from music streamer? Please tell me yes!
sigbergaudio
Norway
I have no idea how common it is, but ours (to pick a not so random example) will autodetect signal from any input, so as long as you don't play from multiple source at once, the concept you are proposing would work.
