powering AEon 2 noire's
AMKAM
planed to buy AEon 2 noire. what i hve is ifi zen dac/can and i heard noire need more power, so the Q is
do i need to upgrade my amp or will it be enough to run noire's in bal through zen can?
if amp is a must this are what i hve in mind
Singxer - SA-1
TOPPING - A90 Discrete
Cayin - iHA-6
or the whole package
FiiO - K9 Pro ESS
i am open to any suggestions.
Jimbob54
Singxer - SA-1
Cayin - iHA-6
FiiO - K9 Pro ESS
Somebody else will give you the stats but if you are set on the AN regardless, buy them and see if the Can is enough.
I think you'll be fine and you lose nothing by trying in existing rig then buying bigger amp if needed. My Aeon RT aren't that hard to drive.
A
AMKAM
are u powering ur aeon's bal?
Snoopy
My noire aren't super hard to drive either but with negative gain and EQ settings it's nice to have a bit headroom.
But still my Singxer SA-1 and Smsl SP400 are plenty powerful in low gain even with 10 band EQ and 3-4db negative gain.
I'm pretty sure you could get away with a topping mobile headphone amp.
milotrain
I've used a Grace M903, Grace M900, they need to be maxed to drive the A2N loud enough inside of protools, I'll try one off my laptop today. The Topping NX4 has plenty of gain. Fiio BTR5 won't drive them loud enough (unbalanced, haven't tried balanced), neither will my laptop MBP or iphone. Rednet AM2 falls apart at louder volumes.
