Pre Amp Needed?
ohnonate
Hi, just wanting to get some advice as i am kind of new to this.
I was wanting to know if a Pre amp is needed if intend to connect a Denafrips Aeries II Dac to ELAC NAVIS ARB51 Speakers?
So i currently have a Bluesound Node 2i Connected via RCA into a pair of ELAC NAVIS ARB 51 Active Bookshelf Speakers.
I was wanting to know would i need a Pre Amp to go in between the Denafrips Aeres II and the ELAC Navis.
I have been told this is to get the signal across from The DAC to speakers ? as thsi is only a DAC has no functions ie volume control.
Bluesound Node 2i -> Denafrips Ares II ->Pre Amp ELAC NAVIS ARB51
Please assist
Thank You
Nate
Mart68
England
Yes, you will need to use a pre-amp with them or you will have no control over volume levels.
O
ohnonate
Hi Martin, thanks for the feedback. What confuses me is that i am able to change the volume from Bluesound Node2i App. Is this ok?
Mart68
England
I don't know anything about the Bluesound, Does it have a DAC in it?
Mart68
England
So you are bypassing that into the external DAC - I would use a pre-amp, a passive potentiometer would do, not expensive.
O
ohnonate
So i was able to get my hand on a Denafrips Ares 2 and i am not sure what is going on?
This is my problem.
1. The speakers do not come out of standby mode when i select a song in Spotify. i need to increase the volume a few times for it to turn on? Is this an impedance issue when the Denafrips isn't sending a signal strong enough to the speakers?
2. Also the sound doesn't really sound like its doing much for a $1,200 AUD DAC Compared to the BlUesound Node built in DAC?
So my question is now would a pre amp boost the signal and sent a stronger signal to the ELACS and wake them up on stand by ?
Any suggestion would be great as this is confusing me.
