Kalupaw2
Hi,
So what I'm trying to do is use the PrimeEQ by Voxengo plugin with SoundSource.
I'm struggling with the install of PrimeEQ. The setup guide is confusing. I've attached screenshots of the guide as well as the files provided. Can anybody tell me what file goes where?
Thanks
_thelaughingman
Best way to do the install is to open up two finder windows, one for the folder where you plugins are downloaded to and then other you for the plug-ins folder where you will drag the file to.
You can also go to the folder from Finder by going to the Go To menu on the taskbar and select Go To folder and type in or copy paste the path to where you need to install the plugins.
K
Kalupaw2
Cool thank you.
The problem I'm having is which file goes into which in my audio library. From my perspective, the guide doesn't make it clear which files goes into what folder. For example the component file? Which one is that?
_thelaughingman
Component file goes into this path /Library/Audio/Plug-Ins/Components/.
_thelaughingman
Put the .vst files into the component folder even though there isn't a defined .component file for PrimeEQ.
