Hi all,
Due to recent Cambridge Audio DACMagic+ failure I went on the hunt for a new DAC. The SMSL SU-9 fit the bill, and is excellent with a few niggles that might well turn out to be a deal breaker (return of device) if not addressable with setup and/or firmware fix.
Firstly, this is a great DAC. While I'm in the camp that 44.1/16 is plenty enough for home rendering. It's nice to be able to play with full MQA unfolding and DSD. The device has so much potential to be as much as nearly anyone needs. Sadly, there are problems, at least ones I'm having.
1. Some unknown (EMI?) issue is triggering the sonos connect autoswitching input
I've tried everything as many solutions as I can think of, but occasionally Sonos will switch to its analog input when playing other music. This is definitely caused by the DAC. If there's an electrical connection to the sonos it will occasionally trigger the input switch. Electrical connection means:
Direct Coaxial Coaxial from Sonos to DAC
Indirect Coaxial from SONOS to RaspberryPi, to DAC
If the DAC is *ONLY* optically connected, it won't trigger it. However, if the DAC is USB connected to Raspberry Pi, and the Pi in-turn connects electrically via Ethernet on the 2nd Sonos Ethernet port, it will still happen.
I've done many variations of testing here that I won't bore you with.
If I go purely optical from Sonos, to Pi, to DAC and use an ethernet port/wifi for the Pi then it's ok, but to me this is not acceptable because the device is clearly creating some kind of EMI through its ground.
I guess this one can't be genuinely solved by setup or firmare updates but I felt it should be reported to others.
2. Occasionally it loses the left channel
Ok, this never happens in "normal" usage. However, when AB testing, switching sources, plugging unplugging USB, the DAC get confused with its output and kills the left channel. Every few seconds the DAC software tries to reinitialise the channel, it turns on, plays music with a lot of white noise behind it for a couple of seconds, then turns off again - this repeats indefinitely until the DAC is power-cycled.
This feels like it could be cured with a software update to the DAC. Fingers crossed SMSL will pay attention (this thread will be posted to a support ticket with them).
I thnk I've done my testing and research carefully enough to be certain these are SMSL issues (or at least issues with my particular device) but if anybody has experience, remedies, or further input, I'm happy to try further.
