Pros and cons of tweeters in the middle, BTM, in a three-way speaker?
fpitas
Northern Virginia, USA
When I bought my Castle Conway 3s in 2005 they were described as being a d'Appolito design. I think the two mid/woofers were supposed to act like one larger driver?
Sort of. There are big implications for vertical directivity when you do that. You're on your way to a line array.
DanielT
DanielT
Sweden - Слава Україні
I know Ken, having talked with him on other forums about break-in. I have to disagree with him somewhat, especially if time-alignment is low-hanging fruit because of digital delay. Of course, the vast majority of speakers are passive, and pure delay over a wide band is difficult. Here's Rod Elliott's take:
I will read what Rod Elliott writes, thanks for the tip.:)
I read a few weeks ago a bit of that thread I referred to, i.e. this one:
I don't know if I got that much wiser. Also, like you, I can put in a delay if I want,:cool: ...so in practice it's not something I care too much about.But it's always fun to read about the theoretical stuff.:)
dualazmak
Interesting thread, indeed.
In my multichannel multi-driver multi-amplifier active stereo system, I could establish 0.1 msec precision time alignment over all the SP drivers including tweeters and super-tweeters; my very unique (eccentric?) physical alignment (positioning) of super-tweeters described here would be of your interest and reference, I assume.
Edit:
Our ears are located left and right of our head, and hence we are rather sensitive for left-right sound image/allocation. On the other hand, our ears and brain would be relatively gullible with up-and-down sound staging, I assume. I think that my unique physical alignment (positioning) of super-tweeters at under the main SPs, together with the upper tweeters, would give pseud-coaxial sound staging if complete time alignment has been achieved like in my setup, where tweeter and super-tweeter sing together higher than about 8 kHz.
In any way, I would like to suggest those who using super-tweeters to at least try/test the positioning so that super-tweeter and tweeter would sandwich the woofer and squawker from up and down.
DanielT
DanielT
Here is a comment regarding the placement of tweeters:
I-or
Furthermore, placing the tweeter element below the midrange element gives an advantage in that the main lobe is directed upwards (instead of downwards) for a planar baffle.
Edit:
What should be added is that I don't know if it can be seen as a general tip or if it relates more to the DIY construction discussed in that thread. That is to say, the statement applies to its specific conditions.
dualazmak
I-or
Edit:
Above reference and/or my unique super-tweeter positioning would possibly make sense if flexible relative gain control and perfect time alignment could be implemented and achieved, I assume, even though it would be greatly dependent on each setup and room acoustic conditions. Somewhat relating to the topics, possibly my post here would be also of your interest.
valerianf
Los Angeles
I got a 3 way tower speaker that is designed similar to a Canton.
The tweeter is at 32 inches height.
Advantage is direct radiation to the couch and proximity with the center speaker tweeter.
The center sound image is more homogeneous.
It would be nice if Amir could measure a Canton tower speaker.
