- Joined
- Mar 1, 2016
- Messages
- 802
- Likes
- 1,602
A proper SPDIF cable should have an impedance of 75 Ohm and terminated with 75 Ohm (BNC) plugs.
In practice it is often RCA so no 75 Ohm termination at all.
Qne can also use an "analog" cable, whatever its impedance might be.
There is a rule of the thumb called the quarter wavelength rule. As long as the cable is shorter than 1/4 of the wavelength, is will work fine.
My problem is calculating the wavelength.
The SPDIF part is straight forward.
Speed is simple too
Divide speed by the frequency of the signal
Much longer than I expected.
However, in this article http://hinton-instruments.co.uk/reference/audio/digiprimer/pg02.htm the author says wavelength is about sine waves hence we should not use the frequency of the signal but the 7th order. Doing so:
Now I end up with 1,33
What is the right value?
Sample rate | 44,1 | ||
bit | 32 | 1411,2 | |
channel | 2 | 2822,4 | |
Bi-phase encoded | 2 | 5644,8 | Mhz |
Frequency | 5644800 | Hz |
Speed is simple too
Speed vacuum | 299.792.500 | ||
Propagation in coax | 0,7 | ||
Speed cable | 209854750 | m/s | |
Wave length | 37,18 | m | |
Quarter Wavelength | 4 | 9,29 | m |
Freqency | 5644800 | Hz | |
7 th harmonic | 7 | 39513600 | Hz |
Propagation | 0,7 | ||
Wave length | 5,31 | m | |
Quarter Wavelength | 4 | 1,33 | m |
