Qudelix-5K Bluetooth DAC & Headphone Amp
Digital Delay
Thanks to ASR, I discovered this neat device, and have been using it for a week now pairing with my iPhone 12 Pro and Hifiman Sundara.
Using the balanced high 4V output / my Tidal volume on the phone at max / using USB connection / PEQ at -5.5dB, I find that I need to set the Qudelix volume close to max (near 0dB or higher) to get to a nice “rocking loud” level.
Anyone here on similar setup experiencing the same? I do wish for more volume headroom.
raykkho
This is truly a great device, I don't even bother to use my DAP on the road anymore. I haven't tried full size can but using BT LDAC connection, Android, phone on max volume, and my JH Audio JH13 Pro, I use around half of the available volume on the 5K, already quite loud for me. Perhaps your Sundara are very hungry for power. Need to try it with my Emphyrean.
Digital Delay
Would be interesting to know how it pairs with the Emphyrean
Jimbob54
The way the 5k high gain works is interesting if you read the manual. If you are set to "low" gain or whatever it is called, the 5k own volume slider tops out at 0dB. If you engage "high" you can go up to +6dB. 0dB in either setting is exactly the same output level (as you would expect) so to "use" high gain, you have to go above 0, but at the expense of higher noise etc. Whether thats a worthy trade off is up to you and your ears. So basically, in high gain you have 6dB more headroom than you are using
DanTheMan
If you haven't done what Jimbob suggests, you'll have to relax on that bass boost.
Digital Delay
Thanks. Since I’m almost maxed out on phone volume and 5k gain, will try reducing my bass boost by -1 dB to get 1 dB extra headroom.
Digital Delay
I’m already on high gain :facepalm:
Jimbob54
On high gain the volume goes up to plus 6 dB. You said you were running at 0db. You're not using the headroom if that's the case.
Lunafag
It's powerful for a portable amp but it's no magic. I often go like this with LCD-2, balanced, -8dB from EQ.
Digital Delay
I wrote 0 dB or higher... (normally around +2 dB :)
I guess my EQ -5.5 dB has offset much of the high gain extra headroom. Hope I’m making sense.
Jimbob54
It does, but the last few dB on the "dial" are the most obvious jumps in loudness. So you probably wont notice a couple of dB move from -60 dB to -58 dB but you will sure notice -6 to -4 and even more so -2 to 0. Go from +2 to +6 (briefly) on a "loud" track and you'll see what I mean. And yes, the EQ is eating the eating the headroom. temporarily disable the eq when at , say -10 dB and youll see.
Brianc
Reposting a question here in the appropriate thread. If used with an Atom amp, could you connect the 3.5mm output to the Atoms 3.5mm aux input or to the line level RCA inputs?
mSpot
It's very likely that the two inputs are electrically connected together (you can verify with a tester), and it wouldn't matter which one you use.
Atanasi
They are independent inputs, there is a switching button in the front.
mSpot
An inline switch does make it harder to check whether they are electrically equivalent. You can open up the case and look at how the connectors and switch are connected. I still think it is likely they are equivalent and won't make any difference.
