- Joined
- Jun 5, 2016
- Messages
- 3,162
- Likes
- 5,350
I recently discovered that turning on the "auto standby" setting in Audio Architect on my Crown subwoofer amp only turns off the high power rails, and true standby (<1W consumption) is only possible via engaging the contact closure through the AUX connector. So I want to do that.
Looking around amazon I see a few options that mention 12V triggers and contact closures. I have questions.
First, do I need one per amp or (assuming no disparate delay is required) can one work on two amps? (Reason for asking - still vacillating between adding a Crown DCIn amp to power 7-series monitors, vs. BSS BLU-50 and my existing ATI AT4007. I need to do a hiss test to see if the Crown solution is quieter than the BSS+ATI solution. Also, my AVP manual lists 50mA trigger current, but is ambiguous if that's total or per trigger output. I have a question in to them regarding that ambiguity.)
Second, a quick scan of Amazon turned up a couple inexpensive boards that seem suitable for purpose.
Third, assuming it will not be in a visible place, is a case of some sort necessary? Or can the board just be stuck out of the way somewhere (e.g. double-stick tape to a shelf in a rack cabinet?
- ELK912 and ELK912B "Heavy Dute" [sic] - more expensive than the below but reassuring because the company has a website with technical data sheets, they're also offered by industry suppliers such as Newark. An Amazon review of the B-model states "This little board has all the parts needed to take the 12vdc trigger output from a receiver or preamp and drive a dry-contact-closure detection circuit..." The base model has no such reviews, but the differences between these two seem to be an LED, input style (ELK912B is fussier when dealing with small wires such as inside cut-off headphone cords), 5mA of current draw (30mA for base model, 35mA for B model), and 4 bucks. So I see little reason to get the B-model. Am I missing anything?
- HiLetgo 12V 1 Channel Relay Module With Optocoupler Isolation Support High or Low Level Trigger - this one has fancy lights (do not care) yet is less than half the price of the ELK912B, and a user review could not be more on point: "Perfect for controlling a Crown amp via 12VDC trigger." However, an Amazon review states the current draw is actually 43mA, not the claimed 5mA.
