Radio Frequency (RF) Analysis of Speaker Cables/Reflections
This is an article our technical member @DonH56 kindly wrote on another forum and place. I am copying it here given the recent interest in its content:
Apples vs. oranges, anybody? In this thread we’ll take a look at speaker cables from an RF perspective, not something usually discussed. Although closer to my professional life than the usual audio analysis, I would not have thought of this except for the prodding by (“interaction with” if you prefer) a fellow engineer. I would have said transmission line effects at audio frequencies are negligible. Was I wrong? Well, the jury is still out, but it makes for an interesting thread, so here we go!
Recall that wires have impedance terms (resistance, inductance, capacitance, conductance – RLCG) distributed along their length. They reduce the cable’s bandwidth, reduce the effective damping factor at the speaker terminals, and add distortion (though the cable’s nonlinearity at audio is insignificant – I am not covering that now). Also remember that it takes time to get from one end of the wire to the other, even for an ideal line. Finally, you may recall from the DAC Reflections thread that mismatches among the source (amplifier), line (speaker cable), and load (speaker) impedances cause reflections. That is, not all the energy goes straight into the load as we would hope, but some gets reflected back. The bigger the mismatch, the bigger the reflection, the less signal is initially delivered to the load, and the longer it takes to settle to its final value.
First, let’s get the equations out of the way:
Figure 1: Equation set.
Note vp is for the electrical signal, not the sound waves out of the speaker! Sound travels around 1130 feet/s, while the signal in the wires typically travels about 1/2 the speed of light (1/2 of 186 thousand miles/s) for an audio cable (can be 0.9c or more for RF cables). The good news is I am not going to use these equations any more, but they are the basis of the pictures that follow. For more info, look up transmission lines on Wikipedia or your favorite RF handbook.
Now let’s look at a simple circuit formed by an ideal amplifier (a perfect voltage source), a short (20-foot) speaker cable, and ideal 8-ohm resistor to model the speaker. For speaker cables I used an ideal and lossy 8-ohm cable, and ideal and lossy 93-ohm cable that is essentially the original Monster Cable. The delay time is ~45 ns for these cables. I applied a step input with a 10 ns edge (8 ns rise time, equivalent to ~44 MHz bandwidth). The results for several test cases are shown in Figure 2, with the output voltages measured at the load.
Figure 2: Ideal amp, load trials with 10 ns input step.
Now, with an 8-ohm cable and 8-ohm load the match is perfect so no reflections occur (gamma = 0). It is difficult to see but the ideal 8-ohm cable rises smoothly in 8 ns and starting 45 ns after the input step as expected. The lossy 8-ohm cable is nearly the same, but with one tiny little perturbation at the top (barely visible in the green line) and rise time is 8.05 ns. I cannot imagine anyone would hear any impact from either 8-ohm cable.
The 93-ohm case is much more interesting. Now we see mismatches causing reflections and the resulting longer settling time. Because of the mismatch between line (93 ohms) and load (8 ohms), only part (about 16 %) of the initial energy is absorbed, and the rest is reflected (“bounced”) back to the amp. There it is again reflected (100% since the amp is ideal), and travels back to the load (speaker), adding a bit more power but again reflecting most of the energy back. We see the signal at the speaker building in steps throughout this process. This back and forth goes on for several microseconds as seen in the picture, with the voltage at the speaker gradually rising as a little more energy is passed on to the load at each “bounce”. The effective rise time is now about 1.2 us (~300 kHz bandwidth) – still well above the audible band, but much lower than the ideally-matched case. Again, the difference in rise time between the ideal 93-ohm line (1.16 us) and lossy line (1.18 us) is insignificant.
Let’s talk just a bit about this bouncing that is going on… Some of us are old enough to remember those hard rubber “Superballs”, and the rest have hopefully seen how a small plastic ball bounces. I am going to use that for an analogy (and yes, I know this is not terribly rigorous, please bear with me). The ball is the signal, and the ground the load. What we’d like is for the load (ground) to instantly absorb all of the ball’s (signal) energy, giving nothing back. This would be like throwing the ball into a pool of thick, gooey mud. One splat, and that’s it. The other extreme would be smooth concrete. The ball hits and bounces, bounces nearly as high the second time, and bounces many times before all its energy is gone. Only a little is transferred to the concrete with each contact. In between is something like grass; a few bounces and we’re done. Perfect energy transfer would be like mud, with a reflection coefficient of 0, and concrete is a coefficient of almost 1 with almost no energy transferred.
The question of whether the mismatch matters is an interesting one. I think it is safe to say that a 45 ns reflection is unlikely to be heard by anyone. Our ears should average those little steps so we don’t hear them (I think). As for the effective change in rise time, a 20 kHz sine wave has a rise time of 17.5 us, about an order of magnitude slower than the cable. So, the 93-ohm cable would have to be ten times longer (200 feet) to approach the rise time of a 20 kHz signal. Or, have an impedance ten times higher, i.e. a cable with very low capacitance and/or very high inductance. There may be such cables; I do not know. From a rise time, or bandwidth, perspective the cable does not seem to matter.
The other argument that has been made is how the reflections impact our perception of location. It was shown in a much earlier thread (not one of mine, though I did run some numbers) that we can actually perceive timing changes in the microsecond region. This is based upon our ability to recognize a small shift in location which, when calculated as a time difference between our two ears, works out to just a couple of microseconds. So, might a relative time shift of 1 – 2 us caused by reflections be noticed? The problem with this theory is that, treated as a time constant, again there is an order of magnitude between the cable’s time constant and that of a 20 kHz signal. The audio signal, especially when comprised of many different tones (like music), may well mask the effect. And, the reflections operate upon all signals, meaning all edges are delayed. Finally, if the mismatch is the same for each speaker, the same signal will have the same equivalent time delay for each speaker. Of course, different frequencies will see different impedances in real speakers, thus the reflections will be different for different frequencies. This could cause the image to shift (vary) with frequency. Clearly it can get complicated... What is also clear is that transmission line effects can matter in speaker cables, though whether these effects are audible I can’t say.
One last look at this fairly ideal case: what if a more realistic (slower) rise time is used? A 10 us edge (8 us rise time, a little over 40 kHz) is shown in Figure 3. The reflection “stair steps” are no longer visible and the rise time is essentially the same as the source (8 us) for the 8-ohm and 93-ohm traces. The delay caused by the distributed RLC of the 93-ohm line is visible, however. The 8-ohm lines’ delay is about 45 ns, as expected from T calculated above, but the 93-ohm lines’ delay is about 0.5 us. An ideally-matched line and load renders the LC essentially “invisible”, but a mismatch means the distributed impedance is “visible” and impacts the propagation delay consistent with the effective bandwidth. Again, the audibility is a matter of some debate…
Figure 3: Ideal amp, load trials with 10 us input step.
The analysis for bi-wiring is also very interesting, but another day…
RayDunzl
Central Scrutinizer
Riverview FL
I am!
I do!​
I have one!​
I bought one (an old "new" original Wham-O Superball ©1965) a few years ago.
Dropping onto concrete from 71 inches, the first bounce reaches about 64 inches, 90% rebound.
Dropping it 3/4 of an inch or so on my desk. At least 30 bounces here before it buzzes into a not bouncing any more state...
solderdude
The Neitherlands
So... we either need 100 Ohm speakers or Max's Isolda cable when we have long lengths of speaker wire.
Where is the skin effect which also seems to play a role at the higher frequencies. Coax cables are not plagued by this due to their construction but the monster cable may well be.
2 factors resulting in a similar effect (upper treble roll-off)
Then there is another compounding factor.
The tweeter that must reproduce such high frequencies has some mass as well that needs to be put in motion and stop on a dime but rather behaves like one of those balls in some cases.
Real world issues can be such a pain.
mikehoopes
Campbell, CA
Has anyone tried to "impedance match" the floor surface with the ball? I imagine a trampoline-suspended surface with damped springs.
JohnPM
Brings back memories of using the TDR kit to measure cables back in the day. More interesting for digital interconnects than speaker cables mind, especially those terminated in RCA connectors whose characteristic impedance is a long way from that of any practical interconnect.
KCHANG
Where can we find an 8-ohm speaker cable? Or do we have to make such cables ourselves?
I find it funny that many audiophiles are so obsessed with speaker cables and willing to pay big money for designs with dubious constructions, but none of them seems to have tried to find out if speaker cables with proper impedance values would make a difference in a DBLT.
JohnPM
Why? Generally speakers don't present 8 ohm resistive loads, at the frequencies where impedance matching has any relevance they can be tens or hundreds of ohms depending on the crossover design. Through the audio range they can vary from low single digits to more than a hundred ohms.
solderdude
The Neitherlands
This thread is because of this thread/train wreck
When you want to experiment, just for the fun of it, and don't want to spend a fortune on expensive cables or paralleling coax cables you may want to try this:
Cat5 cable is 100 Ohm per pair. 4 pairs in 1 cable. so you can make a 25 Ohm cable with one cable and thus need 3 of those cables in parallel.
This will get you close to 8 Ohm with a very low investment.
You need to tie all white stripe wires together and all colored ones together.
Then try to blind test it against other cables or other some very expensive high capacity cables.
SIY
Alfred, NY
The peddler in question suggests Zobels to make the impedance match worse and increase the “need” for what he’s selling.
KCHANG
Actually, already been there, done that, when years ago braiding multiple Cat5 cables into one DIY speaker cable was the fad. I don't recall hearing something clearly "superior." Maybe it was because I used four cables instead of 3, so the impedance was only 6.25 ohms so it was not a good match with the 8-ohm speakers ;) (this is a joke obviously, as speaker impedance could vary wildly).
Anyway, if speaker cable impedance mismatch really has any audible impact on the sound, the logical conclusion would be to do away with speaker cables by moving the amplifiers into the speakers (i.e., active speakers).
solderdude
The Neitherlands
RayDunzl
Central Scrutinizer
Riverview FL
Superball vs Callaway Golf Ball
Dropped the Callaway from a little higher off the desk, so the initial bounce takes longer.
Guermantes
Brisbane, Australia
I am!
I do!​
I have one!​
Superballs have other "musical" uses, too: https://www.jampercussion.com/buy/acoustic-percussion-superball-friction-flumi-mallet-single_945.htm
Newk Yuler
That crappy early Monster Cable didn't get between me and rocking out to Rush and Van Halen! A lot. 40 years ago. :facepalm:
I still have that cable somewhere. Last time I saw it it had patina growing a good foot or so up the ends of the yellowed transparent insulation.
tpaxadpom
I have measured a bunch of digital cables on TDR throughout the years as well (along with eye-diagrams). One high end manufacture was using coaxial design with silver wire as a center conductor with air acting as dialectic. Great idea except for the fact the spacing between center conductor and outer shield was completely uncontrolled. I was able to create some really cool graphs on TDR by bending wire along its length... Some designs surprised me as I do not know why they have choosen to use non 75 Ohm cable. Monster Cable Datalink 100 is one such example. The cable measures 65Ohm all the way (minus RCA termination), yet they claim it is 75Ohm cable. All of their video cables are spot on 75Ohms, shoot getting 75Ohm cable is not that difficult. I have some cables I bought at Dollar Tree store and they were spot on 75Ohm, though monster for some reason decided that 65Ohm would be a better choice for SPDIF....
Zog
The way forward is clear. I am going to buy some of these superballs and drill holes in them and pass my speaker cables through. They will look something like ferrite rings. This will give the music more bounce. o_O
mansr
Hampshire
You've heard of cable lifters. Get ready for CABLE BOUNCERS!
Speedskater
Cleveland, Ohio USA
I must be missing something! Why would anyone care about the Radio Frequency Transmission Line Characteristics in a Low Passed audio signal cable? Cables behave much differently well above 100kHz than they do at audio frequencies.
Don't fall into the trap that snake-oil marketing departments use. That of taking engineering knowledge way out of context and then misapplying it.
