- Joined
- Feb 23, 2016
- Messages
- 20,934
- Likes
- 38,022
Are those glues you mentioned 'fast acting' ? Ie can I hold it in place with my hand or are they longer setting ( curing) compounds?
The Aleen's Tacky glue is pretty thick from the beginning. It doesn't just run away. Sets pretty well in a few minutes, and excess wipes up with water.
The other stuff is either thick or sticks on contact. Sort of a rubber contact cement. It won't cure to full strength immediately, but will stick in place right away. The epoxy is maybe thinner than gel, but will hold well enough in a few minutes.
If the maker said gel superglue, then I would use what you ordered. Then again, it let go didn't it? Just make sure you put a wider coating on than they did. I would mask off around it with wax paper.
