Reattaching Driver Membrane
Allswell
Hello,
How can I reattach the driver membrane back onto the frame (ring)? I accidently tore it off trying to fix the wires...
Any tips ?
Thank you
Vini darko
Dorset England
A
Allswell
You could use UV cured glue, for glass. Its will stick properly
Thank you for the hint.
Is this technique something you've seen before in repairing small drivers like this? If so, I don't suppose you know of a guide/pictures I could reference.
adolf.herman
Here is my tutorial
First you have to attach the membrane and the ring with UV adhesive for glass.
Then use this tutorial..
adolf.herman
The tutorial on the video are incomplete for earbuds driver like your case. Please using uv cured adhesive for glass.. Put some on the ring and ray it with uv. Then you could glue the membrane to magnet base and soldering. Pretty easy.
