Gabriel3_89
- Joined
- Nov 5, 2022
- Messages
- 2
- Likes
- 0
Hello, i'm a new member from Italy, i like this forum and all the beautiful devices reviews with plenty of precise and useful data!
I would like some advice:
I've an Lp60x, (it's my first turntable and i'm very satisfied), that is connected to an onkyo 606 avr. Compared to other sources i need to crank up the volume much more, i know that the signal of a turntables is much more weak then say a cd player, so this is in part normal. But i was wondering if adding a phono preamp (and obviously excluding the LP60x built in) could solve the problem. And maybe improve sound quality... The focus is acquire more volume and dynamic.
Budget is about 100€
I found:
ART DJPRE-2 67€ (but i'm concerned about phase problems seen in the review)
Pro-Ject Phono Box MM 69€
Fosi Audio BOX X2 69€
Fosi Audio Box X4 85€
iFi ZEN Air Phono 113€
Real Cable MINI-LP50 75€
I like Geat Punchy Bass!
which one do you recommend? And do you recommend anything else in this price range?
Thank you
I found:
Thank you
