Recommendation for portable DAC+AMP w/ bluetooth under $500
ke7in
Hi all,
I'm looking at the Fiio Q5S as it does both bluetooth and wired. At home I'm listening on a DT770 Pro 80 ohm and when I'm out and about using bluetooth. Appreciate some suggestions for comparable units.
And this may be a stupid question but are the bluetooth enabled amps intended as receivers to be paired with wired headphones? Or are they wired to the source (ie. phone) and transmitting to bluetooth headphones?
Thanks!
Kevin
twsecrest
California
Suggest you replace the DT770 80-Ohm, there are better headphones that are easier to drive.
bobbooo
Qudelix 5K, includes a fully parametric hardware equalizer for system-wide EQing from any source, which is a complete game-changer when it comes to audio quality.
Boris Badinov
The Humorist
Georgia, USA
Hi all,
Thanks!
Kevin
You might look into the Loxjie D30 (reviewed Here ). I recently bought one for my desk and really like it. It is BT capable, but it receives signal from pc, tablet, phone etc. and you need wired headphones.
K
ke7in
Thanks for the feedback. These are also my reference headphones for mixing so trying to get double duty =)
