Vacceo
- Joined
- Mar 9, 2022
- Messages
- 2,701
- Likes
- 2,855
That's why I said in principle. Amps are easier due to less heat on a larger surface. However, it would be interesting to see a multichannel amp with coldplates for water-cooling, even if just as a project and experiment.In terms of what types of coolers you'd use, agree. However, a CPU usually has a ton of heat (up to a few hundred watts) coming from a small area. A power amp needs to cool a larger area.
Luckily in this case seems like Nord has successfully coupled the amps to the case, so that blowing a bit of air around in the cabinet does the trick. That style of cooling is NOT recommended for CPUs
In day to day use, a fan rack is more than enough.
