Rega integrated amplifiers - good?
Corvuscorone
Partly yes
Some of the amps were clipping, maybe? That would explain what you perce
Some of the amps were clipping, maybe? That would explain what you perceived.
Partly yes. Most of the cheap class D amplifiers have a resistance-dependent frequency curve and are too low-powered to drive all speakers correctly. This problem does not exist in higher-power class AB amplifiers and class D Hypex ncore amplifiers. Good bass reproduction requires sufficient power when listening at high volumes.
Corvuscorone
...and the room acoustics have the greatest influence on the sound quality, especially in terms of bass. For the cheapest price, better sound reproduction can be obtained with adequate acoustics in the listening room.
DSJR
Suffolk Coastal, UK
Room-speaker interactions are the last thing that dealers seem to worry about, as the next 'box' up the range and upgrade ladder at higher price and profit will 'fix it' in their minds. been there and done that on both sides of the fence in my less 'clued-up' younger days.
mike70
Dealers knows perfectly that sound also gets with the eyes :)
Not only by beautiful / heavy cases / VUs / whatever ... brand name helps.
Your brain do the rest, but I thought anyone here in ASR knows that well.
