Repurpose an AVR (without preamp inputs) as a power amp?
danovator
Hello all! I’m looking to add some amp channels to my setup and I’m wondering how involved it would be to connect my avr’s pre-outs to the amplifier section of my mothballed old avr which does not have preamp inputs – an Onkyo TX-NR1010. I’ve poked around the forums here and done a bunch of internet searches but I can’t seem to find much discussion on a project like this.
I realize that given the lesser quality of amps in an avr this may not be a common activity vs purchasing external amps but the measurements of the Onkyo’s amps look decent per Archimago’s testing of a similar unit and I enjoyed the sound quality when it was in the system.
If you’ve got a link to share for something similar that’d be much appreciated or advice along the lines of…”Yeah, you just gotta wire an RCA jack onto the amplifier board” vs “Hmmm…you're taking on lots of steps that require an electrical engineering degree."
Thanks much!
MaxwellsEq
It depends on the design. You may be lucky and there's an obvious part of the circuit where you can add an RCA socket. It's probably more likely that there is no such place. If that's the case, you may need to build a resistor network to change voltages and use capacitors to block DC. This may work, but you'd need test gear to prove that the result measures OK and you've not introduced some instability.
D
danovator
Thanks for the info - very helpful. Gotta know my limits... Sure, I can copy someone else's instructable but I'm not going to teach myself electrical engineering and set up a testing lab.
The good news...I'm in the market for some amplifiers!
