No doubt driven by the market demand for soundbars, this outfit is producing skinny rectangular 'racetrack' woofers with an unusual linear voice coil:
If you look, the voice coil is actually wound in the vertical axis, so it looks like a line if you're looking from the front of the woofer. It's almost like a voicecoil on its side.
This particular unit has four neo magnets.
It looks like the different magnets have slightly different strength, or gap distance?
Parts Express has them on sale:
As usual, all the interesting audio engineering is happening in sound reinforcement and soundbars.
Resonado | Redefining the Shape of Sound
www.resonado.com
Resonado’s patented Res-Core architecture enables a wider bandwidth of pistonic behavior - a perfectly even wavefront emanates from the surface of our diaphragms, which creates crisp sound reproduction and reinforces the breadth of the soundstage found in modern music.
www.resonado.com
- Dimensions: 2-1/4" W x 6-15/16" L
- Power Handling (RMS): 35
- Power Handling (MAX): 70
- Impedance: 4Ω
- Frequency Response: 50 to 2,500Hz
- Sensitivity: 79.6 dB @ 2.83V/1m
- Xmax @ 82% BL: ±4.7 mm
- Xmech: ±12 mm
