Revel 328be: Vertical dispersion
Will2campb
From the vertical dispersion chart, if the speakers are 8 feet apart, the listener is 10 feet away, and the listener’s ears are at 37 inches, would the response be ideal? The 328be’s tweeter is 49 inches from the floor.
maxxevv
Sancus
a = distance from center to speaker, b = distance from center to listener
a = 48", b = 120"
c = √(a² +b²) = ~129" (distance from speaker to listener)
a = difference between tweeter and ear height
b = distance to speaker
a = 12", b = 129"
c = √(a² +b²) = 129.6"
∠α = arcsin(a/c) = ~5.3°
No issue with this distance.
You have to be within 20 degrees. Someone needs to do the middle school math to see if that is the case or not. :)
A helpful calculator. ;)
sfdoddsy
Depends on how sensitive you are to vertical dispersion issues.
I slump whilst listening and hence am very sensitive to it.
Assuming all other measurements are the same, I’d choose the F228be (or the F226be) plus a pair of good subs for just that reason.
I wouldn’t pay $16k for speakers that tall in the room you describe.
W
Will2campb
Thanks for all the great responses!
