Review and Measurements of Dynaco ST 70
SIY
Alfred, NY
SIY, is there a driver board you'd recommend that ditches the hard to find 7199?
Not sure what's out there these days (I designed my own), but Joe Curcio's board was pretty good and I bet there's some version of it still floating around. His used ECC88-types, and I've done some adaptions of it to use 12AT7 as well, since JJ is making some really excellent ECC81/12AT7 at a very good price.
If someone wants to design a PCB, I can provide what I think is a very good circuit at no charge (I don't make money from hifi sales, it would be a conflict-of-interest in my opinion).
Reactions: DDF
Ron Texas
I had 2 of these back in the day. They were sold for peanuts when I made a long distance move.
DKT88
South Korea
Curcio's web site is still up and he still shows the boards available.
Reactions: DDF
SIY
Alfred, NY
That's good news. It was a very well thought out design, and Joe seemed like a good guy when I met him a few years back.
DKT88
South Korea
I used his drivers for a couple dynakit MkIII amps in the early 90s. I also built his MQ-100 power amps which I still have.
DonH56
Monument, CO
RayDunzl
Central Scrutinizer
Riverview FL
Reactions: trl
Jaimo
Toronto, Canada
I have a ST35, ST70 and a pair of MK3 clones - these are fantastic legacy products and they sound great. My MK3's are point to point wired and modified with switching B+ Neurochrome regulators. To my ears, they sounded better driving my Magnepan MG1.6's than a Bryston 4BST.
restorer-john
Stereophile measured the Dynaco Stereo 70 II, not the same, but...
Wow. That exchange between Stereophile and Bob Rapoport is just just horrible. Never seen anything like it.
I was asked for wideband FFT to see if there are any problematic ultrasonic issues. Here it is:
It is pretty clean.
I swapped the tubes from left to right channel and vice versa. It made the good channel a bit worse for distortion and didn't improve the other. However, the levels now completely match which is good.
Adjusting the bias to lower values improves things a bit. It raises 2nd harmonic and lowers the 3rd. I should measure the inline resistors to see what the actual values are.
Stability is pretty poor though. It went into nasty oscillation a few times. Could hear the chassis rattling! What are the typical causes for this?
SIY
Alfred, NY
Low or high frequency? if the latter, likely the same as any other amp- inadequate phase margin, fixed by either by lowering the dominant pole or increasing the compensation cap in one of the feedback networks.
Stunning. Some of these people have no business sense whatsoever:
It only gets worse after this!
I didn't want to leave it running too long in that mode but for a few seconds, I thought it was stuck producing 60 Hz to the tune of a few watts with no input.
SIY
Alfred, NY
That might be the power supply coughing as the amp does some squegging. It's still an HF oscillation, but it sucks power so the supply sags and the power transformer goes in and out of saturation.
RayDunzl
Central Scrutinizer
Riverview FL
Ouch. I just looked at the pictures and thought I was done.
Reactions: trl
CRKebschull
Germany
SIY, is there a driver board you'd recommend that ditches the hard to find 7199? I have a pair of clean MKIV's collecting dust for the last 30 years.
I may be the only guy on ASR that owns both amps at opposite extremes of the SINAD graph. :)
Hi DDF,
I have a pair of monoblock Hypex NC400 and a set of Kebschull 35/70 monoblocks from a Bavarian manufacturer that is of course long out of business (from the early 80s -- the amp based on the EL34 pentode power stage, EF86 pentode voltage amplifier and 6SN7 concertina phase splitter design developed by Harold Leak for the TL/12 "Point 1" and TL/10 in the mid 40s - 50s).
Although I don't know what the Kebschulls rate in SINAD, I can imagine it's something like the ST 70. The design is what was called "ultralinear" back then. If they didn't weigh like a sack a bricks, I should send them to Amir, so that we can we can see what progress ancient, to old, to those new boutique retro tube amps have made.
I guess it's best to cover the ends of the spectrum, as you say. ;)
