Review and Measurements of Loxjie D10 DAC & HP Amp
This is a review and detailed measurements of Loxjie D10 USB DAC and headphone amplifier. It was kindly sent in by the company for review. The D10 costs US $129 on Amazon including Prime shipping.
Similar to other Loxjie products, the D10 comes in unusual shape and has a choice of red and blue colors:
Putting aside the very sharp corners, the overall feel is good. Usability is not though seeing how the LED indicators are the left side:
Worst yet are the super tiny fonts as you can see (or not). And the LEDs seem to do double duty showing levels or something. I am not sure. :)
The situation gets more complicated seeing how the headphone jack is placed on the other side together with the rest of the rest of connectivity:
The headphone jack should have been in the front at least. As it is, somehow you have to manage your cable situation.
Another odd choice is the micro USB connectors. Why? This is such a large box and so should have standard large USB type B connectors.
There is a second USB input as you see for power. I am assuming it is needed for Coax/Optical input as using it with USB didn't do anything. So you could power the unit with just the one USB jack.
Anyway, I appreciate the attempt to make a different looking unit. Some points need to be given for that.
Note that you can turn the headphone output on and off using a button for people who appreciate that.
DAC Audio Measurements
As usual, let's characterize the DAC portion separately from the headphone amplifier by measuring what comes out of the RCA line outs:
Wow, that is pretty good THD+N distortion and noise. The equivalent SINAD nicely places the D10 in the top bucket of all DACs tested regardless of price:
Output voltage is about 1 dB higher than we need. I dialed it down to get 2 volt but performance remained the same so I stayed with full value for the rest of the tests.
Good news extended to jitter performance:
Linearity was perfect:
Multitone shows some rise in distortion as frequencies go higher but still very good:
Dynamic range was also very good:
Loxjie D10 USB DAC and Headphone Amplifier Dynamic Range Audio Measurements.png
Our hearing dynamic range is about 116 dB so we are definitely transparent here.
Any bad news? Sadly there is one:
Loxjie D10 USB DAC and Headphone Amplifier IMD distortion Audio Measurements.png
The ESS DAC chip IMD Hump attacks us with vengeance. The very good performance of the D10 otherwise makes it more pronounced than would be if say, the noise floor was higher. Such a shame that ESS did not solve this problem on their own and communicated the solution to all of their customers.
Reconstruction filter is excellent, staying flat to 20 kHz but then truncating very well at half the sampling rate of 22.05 kHz:
Loxjie D10 USB DAC and Headphone Amplifier White Noise Filter Response Audio Measurements.png
Headphone Amplifier Audio Measurements
Let's start with distortion and noise versus power using 300 ohm load:
Loxjie D10 USB DAC and Headphone Amplifier Power at 300 ohm Audio Measurements.png
We generally have good noise and distortion but power is not that high.
Switching to 33 ohm shows current delivery is not so good:
Loxjie D10 USB DAC and Headphone Amplifier Power at 33 ohm Audio Measurements.png
Distortion/noise climb good bit and we lack power to even match the Topping DX3 Pro in low gain. Usage of USB power for everything likely limits performance.
Output impedance of 3.9 is decent
EDIT: Original review had the incorrect value for output impedance.
Measuring signal to noise ratio at just 50 millivolt to simulate what happens with very sensitive IEMs, we get an uninspiring number:
Loxjie D10 USB DAC and Headphone Amplifier 50 millivolt Audio Measurements.png
Headphone Amplifier Listening Tests
I started testing with Sennheiser HD-650 headphones. Here power was pretty reasonable. The sound would get bright toward the last 25% but that is probably too high a level for many people.
Next, I went the other extreme with the DROP + MRSPEAKERS ETHER CX with its DC resistance of just 22 ohm. Predictably, the bass notes completely fell apart with each beat at medium to high listening levels. Just not usable here unless you want just background music.
The situation improved a bit with Hifiman HE400i. I could get louder with these before the bass started to distort.
The Loxjie D10 has an innovative form factor and industrial design. It has equal pluses and minuses in practice so I let you judge that aspect. On performance front, its DAC nearly aces all of my tests, going well past its budget pricing. Unfortunately the ESS IMD Hump is there, knocking it back a step or two. Still, I think it provides a very good option for a DAC at such a reasonable price.
On the headphone front, its performance just doesn't match that of the DAC. It is good enough as a "free" option on top of a good DAC. And could be used with sensitive headphones for everyday use. Just don't expect any miracles from it.
Overall, I am going to recommend the Loxjie D10 on strength of its DAC performance and low cost.
I hope you are happy with the pace of reviews as of late. Plan to take a little road trip middle of this coming week. As you can imagine, it cost money to do that so please donate generously using: https://www.audiosciencereview.com/forum/index.php?threads/how-to-support-audio-science-review.8150/
BYRTT
Denmark (Jutland)
...Such a shame that ESS did not solve this problem on their own and communicated the solution to all of their customers...
Well said .....;)
...Reconstruction filter is excellent, staying flat to 20 kHz but then truncating very well at half the sampling rate of 22.05 kHz...
Good to see :) because it looks that real many seems to miss it.
restorer-john
Tks
Prime Shipped, for that price and performance. Nice deal if you want a form factor like that. Seems odd at first, but as long as your headphone wires are long enough, seems pretty cool. All metal too it seems, so that's pretty cool as well.
Leave it to ESS's moronic asses to ship chips with such a horrendous defect though -.-
Thanks Amir, and Loxjie for being open to putting your product through the proper paces.
bunkbail
KTB-like performance, but with case and headamp +$30. Seems like a win for me.
Veri
I think it's a common implementation flaw, which could have come with a warning by ESS to avoid the bug, but it's not impossible to overcome so not a chip defect per se ;)
THW
reeeally not sold on that form factor and especially the ergonomics but good performance otherwise.
headamp sections seems to be an afterthought though.
192kbps
Hello, amirm, what I want to ask is
Why do you always take 400i and 650 for hearing test?
gvl
SoCal
Not a shortage of well designed gear out of China. Next step for them is to figure out a way to not to pick names for their brands that sound like a name of a mythical character from a Chinese fairly tale.
restorer-john
I have just emailed Loxjie looking for recommendations abt. what type of board they suggest to place horizontally in order to get the best compromise in terms of stack stability and sonic performance.
You could use bamboo chop-sticks horizontally across the top to create a support structure, not unlike this Chinese scaffolding, except in miniature:
