Review and Measurements of New JDS Labs Atom Headphone Amp
daftcombo
If I plan to use the Atom as a "power amp", with the volume being driven by an upstream source, how high should I turn the volume on the Atom?
To the max?
The knob only controls the headphones output AFAIK.
solderdude
The Neitherlands
To the max?
to 'power' what exactly ?
small 4 or 8 Ohm speakers ?
solderdude
The Neitherlands
Headphones
Then I would suggest to set the volume of the Atom so that at max volume on the upstream side it the Atom plays as loud as you want the headphones to go. That could be max. volume or lower. That way you get optimal volume control range with the Atom.
ripvw
California's Central Coast
This is exactly what I am doing with my D50S and Atom. The Atom volume pot is not as accurate at lower volume settings and the feel of the pot is less than wonderful - but given the price acceptable. I leave the volume pot on the Atom at 1 o'clock and change the volume from the D50S up and down from -35db to 0db. This gives me sufficient range to accommodate all my sources and allows for precise remote volume setting with mute function. This capability along with the removal of the ESS IMD hump (likely inaudible to me) is the reason I replaced my Khadas Tone Board with the D50S.
if only the pair had balanced XLR connections...
Veri
The newly reviewed E1DA 9038S has no IMD hump and with the right cable could supply balanced line out at much lower price than D50s, too!
Crazy competitive at the current slated price. No screen, chassis or filtering options etc though. But great value!
Music1969
Seems like a very popular combination.
Are you at 1 o'clock in low gain?
And with what headphones? Do you know their sensitivity (dB per mV)?
daftcombo
It's a good idea BUT on the Atom, the volume knob is also the power on knob. Meaning that at 0 (7 o'clock) the unit is off.
So unless someone wants to adjust the volume knob to a definite position any time (1 o'clock for instance), another idea would be to have it at 1 o'clock (so always on) on a power bar with an on/off switch which would power the whole system.
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
iazriel
Just got my Topping D30 and use it along with my Atom. Perfectly happy so far. Quick question though. Shall I use gain or not? With gain, it is already loud at 11 o'clock whereas without gain I can crank it up to 2 o'clock before it becomes uncomfortable. Headphones are DT 770 pro 250 Ohm.
JohnYang1997
China
Unless you are not getting enough loudness with low gain volume max, you use low gain.
escalibur
Wondering if these knobs would fit on Atom :)
https://www.ebay.com/itm/1PCS-Alumi...-solid-volume-potentiometer-knob/263889501713
mewzik
I have an Atom, used in one of my 2 desk setups. 2 questions:
1) For my 2nd desktop setup, for the sake of not having 2x the same thing, what is a good alternative? I am not particularly cost sensitive, but I won't buy something in the several k range. (the Drop THX AAA 789 is not really available in the UK).
2) What is 'in between' the JDS Atom/ 789 (which seem very similar) and say the Benchmark HPA4 ? It is not clear what 'up' from the Atom would even be to go beyond. For 100 GBP it is awesome. It seems - for any price - pretty great. For say 500 GBP is there anything measurably 'better'?
Tx
Veri
It's not really available in the US either ;) lol. It still is the best "bigger" Atom right now though, best you can do is hit up the next pre-order window. Plenty of us ordered one to the EU.
