Review and Measurements of New JDS Labs Atom Headphone Amp
hyperknot
It is the Topping D50. The cables will be too stiff for the KTB if it is NOT in a case.
It'll be in the Audiophonics case of course. I'll post photos when it arrives, in the worst case I'll use some cable ties for the first few months.
solderdude
The Neitherlands
You can use any tube buffer with it.
Most tube buffers have around 0.95x gain or so.
In the light of the Atom, keep it cheap.
Tube buffers just add a little bit of distortion harmonics .
https://www.amazon.com/FX-Audio-TUBE-01-Preamplifier-Black/dp/B01HEQJGPC
Buying something more expensive won't bring more 'magic' just an emptier wallet.
The linked device is a pre-amp though so it has gain and also more 'tube ... ness' than a true buffer.
You can play with both volpots to get more or less 'effect'.
2ko
Currently, I am using DX3 Pro and thinking about paring my dx3 pro with another standalone headphone amp because the dx3 pro amp is just okay. I'm thinking either JDS Atom or JDS EL AMP. Is this upgrade will be worth the money or should I just stick with dx3 pro until I can afford to buy something like THX 789?
deafenears
SMSL SP200 will probably cost around the same price as the JDS EL AMP and performs close to the THX 789. Would be helpful to know what headphone(s) you're planning on driving.
Reactions: 2ko
2ko
Mainly for T50RP MK3 and I also have X2 and HD58x Jubilee. I look into SMSL SP200 it seems like a really amp but I need RCA out for my studio monitors.
magicscreen
Has the Atom a linear or switching mode power supply? I know only it has a 16V AC adapter.
veeceem
Has anyone used JDS Atom as a stereo preamp for power amp? And result? I wonder if this is as good as DAC3/HPA4/RME ADI2
Thanks
veeceem
I can now buy khadas tone board DAC + Atom, a $200 combo to use as preamp for my stereo power amp, instead of a $2200 DAC3 or a $1000 RME ADI2
Sound-quality should be the same!
Order placed!
Hyped!
Fluffy
@veeceem Just a reminder that as far as I know, in the RME ADI2 the cost in not only for a good dac\pre (with balanced outputs), it's also a state of the art headphone amp, digital volume display with real time spectral analysis, many DSP and EQ options, and a remote. For a 1000$ that actually sounds to me like a bargain, even before we get to the world-class DAC part.
maigonis
Can Beyer DT 770 Pro 250 Ohm owners confirm that sound is not distorting? I listen to electronic music, so hi RMS.
AndrovichIV
As an owner, can confirm that JDS Labs Atom (and for that matter the less powerful Liquid Spark) can absolutely drive the 250 Ohm DT 770 to very high volume without distortion
maigonis
Tnx. I have concerns about buying them because I bought Atom for AKG K712 Pro and they still continued to distort. I'm buying new headphones for about almost a year now, AKG was the 7th pair that I have sent back - I'm a bit tired from this. Almost all headphones that I tried had issues whit distortion, Beyer DT 770, 2x 32 Ohm and 2x 80 Ohm versions, AKG K275 (M50x I just didn't liked, but no distortion). My DAC is Focusrite Scarlett 6i6 2nd gen and it is know for weak headphone amp, so I got Atom now. I don't want to send anything back again as I'm a bit embarrassed about this.
I'm sure that source is not distorting, I check whit commercial music on My current headphones and speakers, all are clean.
MRC01
Pacific Northwest
That's strange. Lightning rarely strikes 7 times in the same spot. Have you considered the levels at which you're listening? Does the distortion you're hearing go away at lower levels?
