That trigger functionality is intriguing, especially combined with the auto on/off functionalitySystem menu is such:
is there an "off" option for the "After timer" menu entry? Also, what are the possible Timer values?Display shows the usual stuff:
Can you please update this thread with the answers?Correct, although I have just confirmed the preorder purchasing for the PRO version, I need to get them on the phone on tomorrow to clarify these points.
Me too. I’ve almost bought Motu 8a.Suddenly, the perfect dac for my needs arises!
I will buy this
Power supply?What is missing is...
Nice!
Now if only had a network connection and could act as a Roon endpoint. Maybe next version...
Than is one of the two modules available directly from Okto.Power supply?
Maybe RoPieee can add it..
I briefly ran it but since the output did not go to 2 volt, I chose not to publish it. From member it was as good as the DAC SINAD as the load for headphone amp dashboard is pretty high (600 ohm) so doesn't stress it much.What is SINAD what the headphone out? 108 dB?
The DSP version with Pi out of box running Volumio/Minidsp (https://www.oktoresearch.com/dac8dsp.htm) supports airplay so you can use that for now. Hopefully that gets upgraded in Roon Endpoint.Nice!
who what?
Sounds like a Raspberry Pi vendor.
In honesty though, there is an unfair advantage here. Can you spot it? The output voltage is 3.3 volt, not the usual 4 volt we like to see.
