Review and Measurements of QSC DCA2422 Amp
This is a review and detailed measurements of the QSC DCS2422 "Digital Cinema" Power Amplifier. It is on kind loan from a member. It must be sold through specialty channel as I can't find it available much. From the bit of searching I did, it seems to go for US $550.
This digital cinema characterization applies to the connectivity of the box. Otherwise this is a normal power amplifier in rack mount configuration:
There is a nice dial with wide range of gains you can dial in. I liked the clipping indicator.
There is a speed controlled fan which is good. What is not good in home hifi situation is that even in its slowest mode there is a whine to the fan that is audible from 6 feet away. If you are going to use this amp, it would need to be in an equipment closet.
The back panel shows the locking SpeakON speaker connectors and only a pair of XLR inputs:
Given the programmable gain you can use RCA to XLR cables. I won't go through the rest of the features, selectable with dip switches.
Power Amplifier Measurements
I set a gain close to what I typically see and dialed in enough input for 5 watts of output:
As noted, channel 2 was fine but channel 1 was all over the place. Its SINAD (signal over noise and distortion) hit a low of 49 dB and a high of 83 dB (later in testing). There is some kind of instability there. I noticed that jiggling the speaker cable in that channel caused some variations too so maybe it is mostly the connector.
Channel 2 beats the THD+N spec so that is good.
Here is a warm up sequence although the unit was not at room temp before I started:
So Channel 1 even when "stabilized" still acts different from the other channel.
Using the dashboard average of the two channels, this is what we get compared to other power amps tested:
Frequency response was very good with just a bit of droop at 20 kHz:
QSC DCA2422 Digital Cinema Amplifier Frequency Response Audio Measurements.png
FFT spectrum of 1 kHz tone tells us about the design of this DCA2422:
We see a spike a bit above 100 kHz. QSC does not indicate the topology of the amplifier but does say it has a switching power supply. The switching power supply substantially lowers the weight of this unit and brings high efficiency that way. I suspect the Amp is some kind of class G (multi-voltage class AB amplifier). The spikes we see are I think the switching frequency of the power supply bleeding through. They are comfortably above the audible range and unlike class D amps, at rather low levels. Overall, this is a much cleaner spectrum than I see on class D amplifiers (which use switching power supply and amplifiers).
Testing with 4 ohm load shows copious amount of power available:
We can see channel 1's worse performance just the same here. Compared to our best ever measured power amplifier using Hypex NC400, we have tons more noise and distortion. But we also have far more power at much lower cost.
I finally took the time to properly mount my dummy loads in a rack mount case with a nice switch to select between 4 and 8 ohms so here are the results of latter:
Unlike 4 ohm where we came up short, the 8 ohm measured power is actually better than the specs.
Perhaps it is best to compare the QSC to another commercial amp I have tested: the Crown XLS1502:
QSC DCA2422 Digital Cinema Amplifier Power at 4 Ohms Compared to Crown XLS1502 Audio Measureme...png
If QSC's Channel 1 had behaved better, it would have beat the Crown across the board. As it is, one channel is better, the other much worse. There is higher output power though (sorry the cursor is not set to read that properly from the graph).
Here is how intermodulation distortion rates at different power levels:
Fascinating how closely the QSC tracks the performance of Klipsch Powergate. It of course leaves it in the dust as far as power is concerned.
The QSC DCA2422 amplifier is the typical commercial power amplifier with tons and tons of power in a light and low cost enclosure. Unlike class D competitors, it seems to have a much more stable design. The issue with it is the one channel misbehaving. If that is typical of the rest of the production, then that is not good. If it is just an issue with this specific sample, then this is a good buy for a rack-mount install to drive subwoofers and such. The fan noise rules it out for any kind of "domestic" application.
In the process of crimping a bunch of connectors to build my dummy load, I realized how tough the ratchet style crimping tools are on high-quality yellow ring connectors. Searching for a power version, I found this wonderful tool:
Bad news is that as most things good in life, it costs money, lots of money! $500 to be exact. So Please help fund that by donating generously using:
Patreon: https://www.patreon.com/audiosciencereview), or
upgrading your membership here though Paypal (https://audiosciencereview.com/foru...eview-and-measurements.2164/page-3#post-59054).
daftcombo
Hi Amir,
Thanks for this new good review. Too bad the bad channel isn't like the good one by a mile, otherwise it could have been a very good product.
I saw your graph with the "power supply frequency" artefacts. Could you explain us what they are about? I saw them on other reviews but don't understand why they appear, and if they are audible or not.
I've read on a review that such things at 120Hz for instance (here it is 110 probably) could make the amp sound "warm". What do you think?
When there is a linear power supply, there are diodes that convert the AC waveform from positive to negative, to two positive humps. This will then be smoothed out to become "DC."
The second waveform is post rectification. In US our mains frequency is 60 Hz. So if we see components that are 120 Hz, it usually indicates that the rectification noise from the power supply is bleeding into the output of the amplifier. If we have 60 Hz, that just means that frequency is also leaking into the amp.
In the case of QSC, it is a switching power supply. So it converts the AC to high voltage DC and then back to DC. The latter is done by switching the DC on and off. That switching noise is very powerful and if not filtered exceptionally well, will again bleed into the output of the amplifier as I showed in my graph (the 110 khz and harmonic tones).
Is this what you were asking?
andreasmaaan
Thanks again @amirm. It seems surprising there is such a performance disparity between the channels. Could the unit be broken perhaps?
daftcombo
Yes, thank you for this explanation. When is it audible, does it make the sound "warmer" or just distorded/bad?
Willem
QSC are quite a big player in the pro audio market, so I am a bit surprised by what seem like manufacturing shortcomings. Anyway, it makes me all the more curious to see measurements of the Yamaha Pxx00s series. The P35000s was tested with an AP analyzer by some French engineer, and the results were impressive. As I have said before, on the basis of that test I bought a 2x250 watt P2500s for my son, and it seems to perform impeccably. Unfortunately it would be prohibitive to send it in for a test, all the way from Europe, but there must be plenty of them in the US as well.
RayDunzl
Central Scrutinizer
Riverview FL
It would likely be a constant "hum" at 60 or 120Hz or their harmonics if audible, with or without the music signal.
I would not consider that to change the "sound" other than to add an extraneous noise.
Sythrix
I have 2 QSC RMX850s. I wonder how they compare.
I recently finished modifying one to change the fan to something more tolerable. (Noctua, but that required a step down converter because the stock is 24 V). Haven't actually used them yet, as I'm moving soon.
Thanks for the review!
You just get hum or buzz when it is audible.
The owner bought it used from someone else. So it may be so. I am waiting for him to give me permission to open it. I noticed that one of the speakOn connectors is not secure enough even when locked.
infinitesymphony
I'm liking this Amplifier SINAD graph. Could there be a complete master version of this posted somewhere as was done with the DAC SINAD graph?
I've been keeping an eye on the accumulating speaker amplifier reviews trying to find a nice budget two-channel amp (<$300).
apgood
Did you end up opening it up and seeing if an internal fault was causing the differences in the two channels?
I did open it but nothing was revealing with respect to the connector. It was impressive to see so much electronics in there for so little money.
apgood
Pity I think it probably isn't normal to have that sort of variation between the channels. I have several of the lower power Class AB amps from the DCA series for home theatre use and haven't noticed any audible variations. Can't comment on measureable as only measured the end result with speakers on the end.
Yeah there's a bit of extra circuitry in there for monitoring through Dataport.
proj964
MN
A quick update. I want to thank Amir for testing this amp (yes it's mine). It is a used unit bought sight unseen on eBay and shipped directly to ASR. I replaced the fan with a Noctua NF-A8 fan connected through a 220 ohm, 2 watt series resistor; it is very quiet now. I also built a 12vdc relay box to control the DCA2422 power from the pre-amp 12v trigger out signal through the power amp DataPort. BTW, the inside of the box had a lot of dirty, large dust-bunnies that needed to be given a new home. I didn't use the speakON connectors but the available screw terminal for the speaker wire connection. The unit is functioning very well.
