Review and Measurements of Schiit Fulla (V1) Dac and Headphone Amplifier
This is a review and measurement of the Schiit Fulla DAC and headphone amplifier. It is the version 1 and is on kind loan from a member. If you are interested in V2/current version, I have purchased that, and the review will be forthcoming.
The Version 1 is a diminutive unit, a bit larger than the typical "thumb drive" sized USB DACs. It is made from folded metal like the larger Schiit products.
There are some sharp corners especially around the volume control knob that I wished were rolled off. Speaking of the volume control, it has rather low level of travel but it works and is convenient to have.
Format wise, this is an older DAC so limited to 96 kHz sampling rate as reported by Roon:
Yes, the USB identifier indeed says "I'm Fulla Schiit." Would be quite funny if the performance is great. Let's see if that is so in our measurements. If you are not familiar with my tests, I suggest reading my tutorial on audio measurements here: https://www.audiosciencereview.com/forum/index.php?threads/understanding-audio-measurements.2351/.
Measurements
All measurements are performed over only input over USB. The device is class compliant so I did not have to install any drivers to test it (in exclusive mode through Roon player).
I should say that this being an older device, I am limiting my measurements to a smaller subset of the usual. For comparison, I also show its performance against king of bargain USB thumb drives, Speaka (see https://audiosciencereview.com/foru...-speaka-usb-dac-and-headphone-amplifier.2423/), Audioquest Dragonfly Black and king of performance in this category, the SMSL Idea.
Let's start with jitter and noise with levels matched with SMSL Idea:
As we see, the Schiit Fulla is not competitive with competing products in this category. It has clear set of jitter spikes on 1 kHz boundaries (USB micro-frames?), and significantly higher noise floor. Fortunately the former is limited to -110 dB so not a big audible concern.
I have been asked to also show the results of this test at 44.1 kHz so here it is, comparing it to 48 kHz above:
As we see, even though our main tone changes to a different frequency, the distortion/jitter/noise profile remains essentially identical. So there is no reason to test both sample rates.
Moving on, let's see how the -90 dB sine wave looks like as a test of linearity and noise:
Here, I am giving the Schiit Fulla V1 an advantage with higher output level. Neither seems like a winner. Performance is OK but noisier than most desktop class DACs.
Let's look at THD+N distortion versus level:
SMSL Idea wins by a good margin with the Schiit Fulla mixing in with the rest.
Finally, let's look at output impedance:
We get a nice 0.7 ohm impedance which is pretty good. This means the unit will not change the frequency response of your headphones.
Subjective Listening
I didn't bother comparing the unit to any other. Instead, I just listened to the unit. Using my Sony MDR-V6 headphones with the music on pause, the volume control was pretty scratchy. Turning it up and down would make a clear static sound as the wipers moved. Switching to Sennheiser HD-650, I could not hear it anymore.
Listening to my reference clips, the Sony MDR-V6 sounded quite satisfying. There is plenty of power to drive them. Switching to the high impedance Sennheiser HD-650, the sound became anemic with barely enough power to drive them. This is not atypical for this class product.
The Schiit Fulla V1 DAC and Headphone amp follows the same well travelled path as other Schiit DACs I have tested. Measured performance in critical tests such as Jitter and Noise is simply not competitive. Better job can be done even if it is hard to make a case for the differences being audible.
On the other hand the volume control as small and cheaply made as it is, is quite handy to have. Most USB thumb drive DACs either don't have volume control or have some kind of up/down digital control.
From subjective front, listening with more efficient/lower impedance headphone is quite pleasant. So if that is what you have and can find this unit on the cheap in second hand market, you won't see me hounding you for purchasing it :).
If you like this review, please consider donating funds for these types of hardware purchases using Patreon (https://www.patreon.com/audiosciencereview), or upgrading your membership here though Paypal (https://audiosciencereview.com/foru...eview-and-measurements.2164/page-3#post-59054).
Cosmik
...the volume control was pretty scratchy. Turning it up and down would make a clear static sound as the wipers moved.
Sounds like there is some DC across it. i.e. a volume control should be attenuating AC-only. DC leakage or a volume control with DC across it by 'design' will produce a scratchy sound.
Another test for you: with these amps, make a quick check of the DC output level - should be zero of course. In fact, with all DACs and amps, an extremely important characteristic (as far as I am concerned) is the behaviour at power-off and power-on. Large 'thumps' could damage headphones or blow up speakers. A well-designed device will avoid these problems under any circumstances - it isn't necessarily a trivial problem to solve. Otherwise, you might get something like this:
  • There’s a rather shocking video of an expensive AKG headphone driver being literally deformed by a large DC current when the Asgard is shut off
  • ....kwkarth who owns an Asgard reported his amp has the same problem and he measured the power down glitch at 2.2 volts—about 15 times worse than claimed.
  • AKG reported even 0.25 volts of DC during power down might damage their headphones.
http://nwavguy.blogspot.co.uk/2011/07/banned-at-head-fi.html
SIY
Alfred, NY
Pardon me if this is a question you've answered elsewhere. How do you run the J-test signal into the DUT? Via the AP addressing the device's ASIO driver directly or is it a standalone .wav file played via a player like foobar or JRiver? Or...?
garbulky
I thought that was a very balanced review. Thank you Amirm. Now you've reviewed DAC line but the Gungnir multibit.It's interesting to see that the Fulla does a better job at -90 db than a Bifrost MB does. I also liked that you included your subjective impressions and posted about the impact of the measurements on them. Would be nice to see the power output of the headphone amp.
The latter. I run my media player, Roon, in "bit-exact" mode and play the test file. Then move to AP software and run the spectrum analysis.
You could use the ASIO interface in your AP to do the same. But you would need to install ASIO drivers which I prefer to not do.
One advantage of using my regular media player is that to the extent there is sensitivity to what the PC is doing, then the work profile is the same as when I play regular music.
@amirm
can you check the channel balance with the volume pot at different positions?
Yes, I will do that and power measurements. I started the test late at night and didn't have time to run more.
SIY
Alfred, NY
I likely wasn't clear. As I mentioned in the Request thread, I usually use the ASIO function of the AP for its output, which works perfectly with the Behringer, M-Audio, and Scarlett ASIO drivers, but crashes hard with the CEntrance driver. In order to get some basic data for my AudioXpress review, I had to do a multicomputer kludge, and still couldn't do sweeps because I had to rely on prerecorded test signals.
To be fair, for its intended use, the CEntrance driver works fine (no issues with foobar or J-River, my usual players), so I was curious about whether is was specific to the APx500 software or if it had the same issue with the software in your 2722.
My software cannot use the PC as the generator at all so it is not an issue there. I have no choice but to perform asynchronous operation with it.
Alright. Took fair bit of work but I managed to port my S/PDIF power measurement to USB. Here are the results:
Absolute maximum power is 224 milliwatt. That's at nearly 14% distortion so I don't think you want to use it that way. :) Schiit rates the output at 200 milliwatt @32 ohms. Without clipping but at nearly 1% distortion I get 140 milliwatts. So their truth hangs somewhere between these two extremes. My measurements are with both channels driven by the way.
Overall distortions are fairly high but considering the little device we are dealing with (and lack of data otherwise at this point), I guess it is not too bad. Here is the RME ADI-2 DAC at 10X for a refresher
Quite a bit cleaner as it should be. :)
And here are the channel balance measurements:
At max volume, there is no imbalance. As I reduce the volume, we get this:
We see a growing deviation. With lower volumes still, we get:
The deviation keeps going. I stopped here as the volume is pretty low at this point.
One kind note guys: on USB devices for now, the process of getting data is pretty time consuming. So unless you really need more information, it would be good to spend my resources on measuring other devices than digging more into the current ones.
Says Amir with tired fingers after 3 hours of work to produce the above. :)
DonH56
Monument, CO
Very nice work, Amir, but I can't see why you keep wasting your time on that Schitt... Definitely agree with moving on to better things. :)
stunta
Boston, MA
I was thinking the same thing. miniDSP is begging to be measured, IMHO.
mindbomb
It is 1.6 milliwatt since it is at 150 ohms.
i have an hd6xx, and on my headphone amp atm, I have the volume pot set for peaks around 150mv (for when I was browsing youtube). A small amp like the fulla might be used with lower impedance headphones, and then would have to go lower still, like 50mv. Poor channel balance there would be really annoying for everyday usability.
And then there is iems, which would need even lower voltage than that.
