Review and Measurements of Schiit Jotunheim With AK4490 DAC
This is a review and detailed measurements of Schiit Jotunheim DAC and headphone amplifier with its AK4490 DAC module. It is on kind loan from a member and in this configuration costs $499 plus shipping from Schiit direct. I had previously reviewed Schiit Jotunheim but that was with its multibit DAC. Some rightly objected that perhaps the performance of the unit was limited by its low performing DAC as opposed to headphone amplifier/pre-amp. In this test we remedy that two ways: 1) the included DAC uses the AKM Ak4490 DAC chip instead of multibit DAC used in the other unit and 2) I also test the pre-amp independently of the DAC.
The unit has the same bland, cost optimized packaging of other Schiit products:
The unit is mains powered so is quite hefty and sits where put. Decoding the cryptic symbols, there are USB, RCA and balanced XLR inputs. For output in addition to the latter two in the back, there are 1/4 inch and XLR headphone outputs. So from feature point of view, the Jotunheim is quite good.
As always the trick with Schiit products is how they perform and in the case of mains operated units (i.e. WITHOUT an external power supply), how safe they are. Let's get into that.
DAC Measurements
I am going to start by testing the DAC subsystem by itself using the RCA and XLR outputs. Alas, I see that they are both variable and go up to pretty elevated levels so they are really tapped from the headphone amplifier. Be careful then in turning up the volume too much if driving other audio products.
Let's start with our dashboard of RCA outputs with levels set to the typical 2 volt RMS:
Right away we see a big improvement in performance with SINAD (signal over noise and distortion) jumping up a whopping 10 dB over its multibit version. Unfortunately at 96 dB, it is not going to win any races:
It is squarely in tier 3 of performance (tier 1 being the best). So not broken but also not designed with excellence in mind.
We see that there are mains related (60 Hz and multiples) visible in our FFT spectrum. This is typical of RCA outputs in many products due to poor nature of unbalanced audio interconnects. Let's switch to XLR/Balanced outputs and see if it is still there:
Balanced inputs don't use the ground as a reference so usually they are immune to mains related currents between equipment that upsets RCA connected gear. Yet, we still see that. Let's do our prior experiment of grounding the lid of the unit with a wire to the safety mains:
Schiit Jotunheim AKM4490 DAC Headphone Amplifier Balanced Grounded Measurements.png
As I suspected, the channel in blue is completely good now. And what remains of 60 Hz in red channel is also reduced.
As a final confirmation, let's just touch the volume knob without the grounding wire and see what happens:
Schiit Jotunheim AKM4490 DAC Headphone Amplifier Balanced Touch Volulme Control Hum Measurements.png
Wow, see how much the 60 Hz hump increased in level. This is the classic symptom of ungrounded Schiit Jotunheim. See this thread where I explain the issue in more detail and show how to fix it: https://www.audiosciencereview.com/...otunheim-headphone-amplifier.3733/#post-89406
Note that due to lack of sensitivity of our hearing in low frequency, what I have shown is inaudible. But that is in my situation. In other cases the rise may be substantially higher leading to hearing buzz and hum. The bigger issue beyond fidelity is safety though. A metal enclosure needs to be full grounded to mains safety pin and in this case, it is not. The case is insulated due to finish on the top lid so it does not make electrical contact with the safety ground pin on the IEC outlet. Anyway, let's get back to measurements.
Jitter and noise shows elevated levels of the latter and some spurious responses:
Schiit Jotunheim AKM4490 DAC Headphone Amplifier RCA Jitter Measurements.png
The spikes are all too low to be audible.
Dynamic range misses the 109 dB specification:
Schiit Jotunheim AKM4490 DAC Headphone Amplifier Dynamic Range Measurements.png
Given the variable nature of the output, one probably could play with the volume control to get the specified rating.
The higher noise floor impacts the intermodulation+noise test naturally:
Schiit Jotunheim AKM4490 DAC Headphone Amplifier DAC Intermodulation Distortion Measurements.png
Here is the nature of THD+N with respect to source frequency:
Schiit Jotunheim AKM4490 DAC Headphone Amplifier RCA THD+N vs Frequency Measurements.png
Interesting that it peaks from 2 to 7 kHz. Our hearing is most sensitive in 2 to 5 kHz so it is unfortunate that it wanted to get more distorted there than higher up in frequency range.
Here is our 32-tone test track to simulate "music":
Schiit Jotunheim AKM4490 DAC Headphone Amplifier RCA Multitone Measurements.png
I did not have the chassis grounded with my jumper cable so we see the mains spikes showing up in the spectrum.
Linearity shows lack of perfection but is transparent for CD music:
Schiit Jotunheim AKM4490 DAC Headphone Amplifier RCA Linearity Measurements.png
Finally here is the response of the reconstruction filter measured using white noise:
Schiit Jotunheim AKM4490 DAC Headphone Amplifier RCA Filter Response Measurements.png
Looks like a very slow filter is used which provides way too little attenuation at the "Nyquist" frequency of 22.05 kHz for CD music at 44.1 kHz sampling rate. We only get 11 dB of attenuation where the theory demands infinite level.
Headphone Output Measurements
Let's start with driving the 1/4 inch headphone jack using the USB input (i.e. going through the internal DAC):
Schiit Jotunheim AKM4490 DAC Headphone Amplifier Unbalanced headphone out 300 ohm DAC driven M...png
Power level is very good but despite the much higher price, the Jotunheim fails to outperform the Topping DX3 Pro on that front. Noise is naturally higher as measured before.
Let's measure the performance by feeding the unit from its analog input:
Schiit Jotunheim AKM4490 DAC Headphone Amplifier Unbalanced headphone out 300 ohm pre-amp Meas...png
We get good bit of reduction of noise there. Power output increases some because I am able to push the amplifier section harder than internal DAC. But then again it gets distorted so no sense in doing that. Also, once the amp distorts, it doesn't matter if you use the DAC or not. They both meet at the same place/point as you see in the graphs.
Switching the output load to 33 ohm with analog (RCA) input gets us the typical distortion curves of Schiit headphone amplifiers when stressed:
Schiit Jotunheim AKM4490 DAC Headphone Amplifier Unbalanced headphone out 33 ohm RCA In Measur...png
We see that two stage rise in distortion. First one is some kind of non-linearity which should have been dealt with using better circuit design. The second sudden peak is the unit running out of current and sharply distorting.
As I have shown in the graph in green, the little $99 JDS Labs Atom blows away the Schiit Jotunheim out of the water. It is essentially distortion free until it too runs out of current. That happens at 1 watts with the Atom whereas the distortion starts to rise in Jotunheim at just 50 or so miliwatts.
Since there is XLR (incorrectly called "balanced") outputs, let's measure that using 50 ohm load. And for variety use XLR input:
Schiit Jotunheim AKM4490 DAC Headphone Amplifier balanced headphone out 50 ohm pre-amp vs Mass...png
Same problem as before manifests itself in very early rise in distortion. As such, our other state-of-the-art, the Massdrop THX 789 leaves the Jotunheim in the dust, produce more power at a fraction of the distortion.
Finally, here is the test of channel balance versus position of volume control:
Schiit Jotunheim AKM4490 DAC Headphone Amplifier Headphone Channel Imbalance Measurements.png
Due to use of analog control we get inaccuracies between channels. Until you get to low volumes, it is not too bad at 0.4 dB.
Listening Tests
I did not bother with my usual level matched blind AB tests. Instead I just played some music and turned up the volume to detect distortion. WIth Sennheiser HD-650 there was fair bit of power but once you went past the 2:00 o'clock position on the volume control, you could easily hear the distortion setting in. Similar situation existed with Hifiman HE-400i. Neither could pass my test of loudness without distortion which admittedly means pretty high SPLs (sound levels). :)
Use of traditional delta-sigma DAC chip significantly improves the performance of Schiit Jotunheim versus the multibit version tested before. So if you are going to go this route, that would be my strongest recommendation.
The world has moved on since the Jotunheim was designed and today we have stellar headphone amplifiers in the form of JDS Labs Atom and Massdrop THX AAA 789. Few amplifiers can get close to the performance of these units much less a Schiit headphone amplifier. So while the Jotunheim can be an enjoyable device to use versus lower powered amplifiers, it just doesn't rise up to level of objective performance I like to see in this day and age and at that price.
On the plus side though, this is a very full featured all-in-one unit. Right now I can't think of any other device I have reviewed with the same functionality.
Most important concern here is electrical safety. I continue to be dismayed that Schiit has not recalled all of these units to properly repair them after confirming that the top is supposed to be grounded. On that basis alone, I cannot recommend Schiit Jotunheim in any configuration for purchase.
They say you should save money for a rainy day. It rains for about 6 months here so I need plenty of money!!! Please consider donating funds using:
Patreon: https://www.patreon.com/audiosciencereview), or
upgrading your membership here though Paypal (https://audiosciencereview.com/foru...eview-and-measurements.2164/page-3#post-59054).
pwjazz
and up with twice as many units on your desk
The Jotunheim's footprint is nearly twice that of the Modi or Atom. I would just stack those two and save on desk space.
It would've been a decent product without the electrocution risk.
Let's get t-shirts made with that!
Headphonaholic
I have the black version of this configuration (I am selling it too lol) and I can confirm that there is a hum due to lack of grounding. I have to give some kudos because it looks and feels serious. It's a good looking piece of gear and the idea of modular dacs is clever. Sadly it just isn't very safe and doesn't perform up to it's price point.
invaderzim
NorCal
" Few amplifiers can get close to the performance of these units much less a Schiit headphone amplifier. "
Sure, but do the other amps have catchy names that you can punch your friend and go "get it?" when you tell them the name?
JJB70
Singapore
As I think I said about the other Jotenheim review, products may perform well or perform badly but they should always be safe to use. That Schiit still haven't addressed the earthing issue is a disgrace.
Blumlein 88
I always thought there should be company that makes a product with the same functionality as each Schiit product only with good performance. The name of this company should be Shinola audio.
Nango
D:\EU\GER\Rheinhessen
I wonder @amirm if you shouldn't better stop refering to a hardware that is not any longer available in the market, I feel it is a bit unfair, .... isn't it?
jasonq997
Have they announced that there will be no more drops for the THX units?
@amirm how many other schiit products do you want to test?
Believe it or not, I had no less than three offers to test this specific model/configuration.
You have to put up with one more unit in the queue right now.....
Veri
Have you researched this at all? Massdrop has said they're waiting on new stock. Such a thing can take some time especially with the parts market being shite.
Nango
I wish they droped again as I am waiting to grab mine ....... but even then, will it be exactly the same unit than before ..... And how many will they deliver again? Anyway, it is not freely available like other commercial stuff.
confucius_zero
yet they are often recurring if financially successful. Sennheiser HD6XX headphones are often available.
Veri
THX has factory testing for performance of course :) I mean besides the rare lemon they should all perform the same. there had been factory measurements from before the unit hit its first drop.
jasonq997
OT: What I never dared to ask ...... Why did Amazon Corp. miss this "drop business" at all?
Probably not big enough. Massdrop is specifically designed for savy plugged in niche enthusiasts for things like headphones and pocket knives. Amazon probably wouldn't bother with producing relatively small runs of headphone amplifiers.
