This is the third installment of my response to Schiit Yggdrasil measurements of the unit I tested.
Here, I try to replicate their measurements with
exactly the same parameters, contrasting them with what Topping DX7s does. First up is 1 kHz FFT:
We see all the problems I reported originally in my review of Schiit Yggdrasil. There is fair bit of mains leakage causing those harmonics to the left of our 1 kHz tone. And a spray of harmonic and inharmonic distortion piling on top of each other. If audible, these clearly mask low-level detail in music, not enhance it.
In contrast the Topping DX7s at nearly 1/6 the cost of Yggdrasil, has far cleaner output. No mains contributions. And worst case harmonic spike that is around -100 dB (as opposed to -80 dB in Yggdrasil DAC).
Now, some people say, "well, multibit DACs don't measure as well as delta sigma." Let's look at the Soekris multibit DAC I recently measured:
Once again we see that Schiit Yggdrasil is the only DAC that spits out all of those extra inharmonic distortion spikes.
Sadly from here on, the tests that Schiit ran were different than mine. Without access to Yggdrasil, I had to use their pdf report for reference. And I had to run new tests on Topping DX7s. Again, all parameters were replicated 1:1 from Schiit report.
First CCIF IMD test versus level (I use SMPTE IMD test in my reviews):
We see that the intermodulation distortion is much lower in Topping DX7s. At higher output levels of say, -5 dB, the gap is as much as 30 dB!!!
Folks, getting 5 or 6 dB improvement is a big deal in DAC. But here, the cheaper DAC by far has a whopping 30 dB advantage!
Intermodulation distortion causes distortion spikes to appear before and after our main music tones. The ones before clearly do not occur "in nature" as the argument goes so they are not musical in nature. No way a case can be made that this kind of distortion increase is a good thing or explanation for any preference for Schiit Yggdrasil.
Same test can be run but this time sweeping the frequencies:
We see that as frequencies increase, the intermodulation distortion worsens in Schiit Yggdrasil. Faster switching between levels due to higher frequencies is accentuating switching errors in the multibit DAC.
Once again we have a massive competitive DAC with Topping DX7s pulling ahead by some 25 dB at higher frequencies.
Using Schiit's own measurement of owner's Yggdrasil DAC, we see that the performance is not at all competitive with even modestly priced chinese DACs.
No way can this performance be called excellent or even very good. Yet these were the very labels put on the measurements of the DAC by others such as this by Atomicbob:
Yggdrasil DAC's performance not only lags delta sigma DACs but also other R2R DACs in the FFT test. There is no reason or excuse for a DAC to spit out tons of distortion products that are not even harmonically related to the music tones it is told to play.
Such conclusions only come out and become readily visible when we put the data in context. We show it against competing products. The fastest way to get them ignored is to put out chart after chart without such comparisons. Unfortunately that is what others seem to be doing and in the process, fully confusing customers into thinking the data is better than it is.
This is a design that had not benefited from proper verification. It was released with fair bit of flaws. This is evident in not only my testing, but I have shown it to be true when measured by other fans of the company and its products. Anyone who claims otherwise loves to have his head in the sand.
All of these measurements -- no matter how has done it -- supports the conclusions that I wrote in my multiple reviews of this DAC. To any engineer who looks at a DAC's job as translating digital samples into equivalent analog voltages, the outcome would have been the same.
The cloud of smoke created around my competence or reliability of the measurements is a disservice to the audiophile community which should aspire to see independent verification of manufacturers claims. That they continue to do so against a mountain of evidence I have put forward using the other side's data, is just remarkable. Folks are just blinded by emotion and improper subjective listening tests.
