Hello all,
Just wanted to drop a note how we have many things going against us here. For one, understand that these DACs have discrete output stages. The ones you rate so highly and compare it to are Op-Amp implementations which have an incredible amount of local and global feedback to provide good numbers. This doesn’t come free and that is why we opt to not use them where possible. From what I read, it is very clear to me that we are not considering differences in sound such as timbre, texture, delicacy, attack, decay, emotional connection, etc. because we can get that from a $100 box right? Im not here to debate with (and I won’t) on the legitimacy of Femto clocks, naked Z-Foil resistors, discrete output stages etc. We all have opinions and if it’s not in your religion, I can understand that and we can move on. Given all this, we must remember that a system will only be as revealing as the weakest link! To an extent I feel like my time here is wasteful based on some of these posts, however there are some that might find it helpful.
I would like to point out a few things. First is that measurement numbers are not always what matter the most..
*Most of our DACs have discrete output stages (meaning no op-amp in the audio signal). Noise figures that you are looking for would only be possible when using ICs in the design – such as the ESS Sabre reference design or the Oppo products. In my experience, harmonic distortions have always been more inherent in discrete designs because there aren’t 100s of parts involved which we try to avoid. There are some downsides to this but we feel the upside is worth it.
*Our DAC-2s have a digital volume control. The product is optimized around a volume setting of 53 which is 2v out on this particular unit –enough to clip our most power amplifier. As it is, customers use this DAC with other manufactures amps and some have far less gain which we have to work with as well. As the volume goes down there is a level of digital truncation happening depending on the level selected so we try to aim for a usable range that is still in the sweet spot. Its hard to be a product so flexible without any compromises. If you set it in different settings you will see different results – I’m not claiming 120db just pointing out that it is reliant on the level. I believe 97db is a more accurate number. If you look at noise by itself it is even better.
*The Femto clock is an ultra-precision and low jitter clock – this is the clock that runs the DAC and dictates its internal timing that paves the path for its operation. If you look at the reporting of the Oppo, you will see it is very similar once you consider the scaling differences – actually, our noise floor of the measurement appears to be about 15db better!
*Remote – I have the very first remote we ordered with the rubberized coating which is still not sicky. What people don’t understand is that cleaners with chemicals to disinfect happens to also break down the rubberized coating. we have some without this coating for those worried about it but for the most part is not a problem.
*The cost of the unit surely isn’t cheap and we don’t claim to be the least expensive. How the price is formulated is directly proportional to the cost. This unit has particularly high cost in the naked Z-foils that are hand made in Texas, the ESS chip as we know it, the Crystek clock as noted, Dale copper leaded/non inductive resistors (if not naked Zs), and most of all – labor to build the unit. The metal work is sourced local from our county as well. All of this adds up to a much more expensive product than what can be had from others who import from overseas.
If there was a direct correlation to what we hear vs what we measure then that magic test box would allow us all to produce the exact same sounding products. I would like to think you all realize that there are things you can hear but not measure, and measure that you cannot hear. Glad to see that there are a couple of people mentioning they enjoy this dac and that it doesn’t sound as bad as the pink panther suggests - Thank you to those of you who did! I also talked to the individual who sent this unit in who noted to me after this review that he still has it in his main system just that he wishes there was some good numbers behind what he was hearing. Rightfully so but what really matters is what we hear and most of what we are talking about here is so minuscule on the measurement side that it should be accepted for benefit that it has rather than the meter it does not peg.
