Review of NanoPi NEO2: World's Smallest Audio Streamer
bzfrp
It is not difficult to install RoonBridge on any Linux distribution on a SBC if you know how to use ssh. (See http://kb.roonlabs.com/LinuxInstall )
Manual Installation example (If wget and tar are installed) (run commands as root):
Code:
mkdir /opt  (create a directory if it doesn't exist)
cd /opt
wget http://download.roonlabs.com/builds/RoonBridge_linuxarmv8.tar.bz2 (download this file for ARM 64 bit Linux)
( If your Linux is 32 bit, download http://download.roonlabs.com/builds/RoonBridge_linuxarmv7hf.tar.bz2 )
tar xf RoonBridge_linuxarmv8.tar.bz2  (extract RoonBridge)
/opt/RoonBridge/start.sh (run RoonBridge)
somebodyelse
RoPieee on a Raspberry Pi is as easy as a diy roon endpoint gets. If that's too much trial and error for you then you'll need to look at roon ready streamers.
somebodyelse
You've asked for something that so far as we know doesn't exist. We've tried to help by giving you a number of options that come close to the requirements you've mentioned to that point, but aren't quite there. If no compromise is acceptable that's fine, but I'm out of things to suggest.
Ruudv033
Thxs anyway
bzfrp
A new similar SBC ZeroPi is out. :)
https://www.friendlyarm.com/index.php?route=product/product&product_id=266
Here is a presentation showing the differences against NanoPi NEO
https://www.cnx-software.com/2019/09/05/zeropi-allwinner-h3-sbc-gigabit-ethernet-spi-flash
ZeroPi seems to me to be a good choice for audio because the removed components have no use for USB audio, but Gigabit Ethernet could a +.
I bought Zero Pi + Metal Combo (assembled). It's currently running with Buildroot ( https://github.com/bz31/Buildroot )
dsnyder0cnn
Sounds great. Do you know if it works with multichannel DACs? To be more precise - can you choose a 7.1 config in Roon?
I've tested the NEO2 with my Emotiva RMC-1L. Only two channels detected, but this could just be an Emotiva thing.
Aldoszx
Hi all.
I have NEO2 512 MB version with case (FriendlyELEC starter kit).
I am trying to get it working properly, but no chance until now.
I have just tried whit Tone Board, DacMagic XS and Topping D50s.
Even whit D50s, with separate 5v 1A power supply, there are glitches and the sound is distorted from time to time.
Same with both Tone Board adn DacMagic XS.
I am using DietPi with Roon Bridge.
Am I missing something?
QMuse
Hi all.
Yup, you're missing this - it has been proven as a reliable audio platform. :D
Aldoszx
Thank you !
I have, i think, 9 of those.
From RPi 1B to RPi4 (I think I have almost all models, even RPi Zero W and RPi 3A).
RPi works just fine with I2S and USB DACs.
But right now i am trying to use this little NEO2.
QMuse
Thank you !
That was a joke, I saw in your sig that you already have RPI4. :)
Aldoszx
I think I am very focused on NEO2, so I am sorry I took your post very serious. :)
However, Amir had positive results, so I am wondering why I could not.
QMuse
No problem. :)
Hard to tell as you didn't provide any info nor diagnostics. For a start, what material were you playing and what was the CPU utilisation?
Btw, you'll probably get more help on DietPi forum than here regarding this partiular issue.
