K.Trout
Unfortunately no, the app auto-fits the vertical scale (as best it can).
I’ve been using HouseCurve for a couple weeks and it’s great so far. Quite impressed. It’s easy to use and understand. And I just realized it can be used with calibrated mics as well. You’re going to make a killing with this app when the word gets around I’m sure.
ErVikingo
FL USA
@Greg Wilding cool app!
What do you make of this. This a measurement of my system as setup “by ear”
Greg Wilding
Glad you like the app! Your measurement looks a tad wobbly in the bass region to me... but it's hard to say much from a single measurement. If your ears are happy, you're winning :). Shoot me a message if you want some help.
mmi
HouseCurve is great! Perfect for averaged measurements.
Regarding replicating the REW moving mic measurement technique discussed in other posts here, I have searched high and low and it seems there isn’t a single iOS RTA / FFT app on the market with data export + adjustable slope or octave “bins” to account for the falling response you get with pink noise.
Audio Frequency Analyser by Toon gets the closest, it has a slope toggle that adjusts things perfectly for pink noise, but unfortunately doesn’t allow exporting data and has very little other config besides quite effective averaging. Great for quick in room measurements with your phone to sanity check and grab screenshots tho.
Studiosixdigital’s FFT app and SignalScopeX both get 95% there with everything else (for a cost!) but frustratingly no adjustment to account for pink noise. Am I missing something?
Yoku-San
Cologne, Germany
Any chance you will release an Android version of it?
Terry22
Hi Greg,
thank you for this great software.
Will you release soon an update with 352khz filters export?
best regards,
Terry
Greg Wilding
I have no plans at this time, though many have asked. I'm a solo dev and there's only so much time on the weekend :)
This is on the list. What's blocking me is a solution to export wav files with that sample rate on iOS. The library I'm using can only do up to 192 KHz (last I checked anyway)
Terry22
thank you for your answer.
As roon(in my settings dsd512 hqplayer Sinc-L) upsamples to 352khz before aplying the convolution filter,
do you know which one of housecure filters is used? 176khz?
harisk2
Studiosixdigital’s FFT app and SignalScopeX both get 95% there with everything else (for a cost!) but frustratingly no adjustment to account for pink noise. Am I missing something? I recently stumbled upon thepokies 84 net Australia https://thepokies84netaustralia.com/ , and I must say it's been a delightful discovery. The variety of games and user-friendly interface make it a top-notch online gaming platform. The immersive experience and quality graphics enhance the overall enjoyment. While discussing casino minimum bets on cruises, I can't help but appreciate the options available on site. It's a great choice for those who love table games, providing a diverse range of options with varying minimum bets. If you're looking for an engaging online casino experience, I highly recommend checking it out. It might just become your go-to destination for thrilling casino games. Happy gaming!
mmi
Following up on my post above, I ended up finding Sound Spectrum Pro. It’s RTA mode ticks all the boxes for quick high quality moving mic measurements on the phone.
DrSpan
Hi there and respect for the wonderful app!
I just tested it but unfortunately if i am honest i cant interpret it-make sense of what the aim is. Meaning, is the „ideal“ to get as close to the yellow line as possible?
I am used to Equalizing music but Room acoustics is a different world
I`ve never used this kind of software or any measurement software at all. I did a quick sweep at my parents place cause i am visiting and cant wait to test it in my place when i am back. They were like „did you hear that noise? What was this?“ and i am lmao
What does this Plot say? Or better said, what would be the first thing you say apart from that it is a completely acoustically untreated kitchen?
I would love to start learning how to interpret what i am seeing in the plots
Peace!
FrantzM
Funny. I had this app on my phone for a while and decided to try it today the found this thread …
The app is surprisingly good .. the other surprise is how good the microphone of the iPhone is …
Will buy the paid version soon.
Peace.
Greg Wilding
Peace!
Thanks! Check out https://housecurve.com/tuning. It'll give you an idea of what the app does and how you can apply it to your kitchen. I was inspired to make the app after trying to tune my own kitchen by ear :)
TheOhGee
Hi Greg, great to see active support on here. I've tried finding info on several use cases (and read the comprehensive docs section on your site) but can't seem to find the answer to my question... hopefully you're the guy! ;)
Can I use HouseCurve to measure the frequency response of a diy 2-way speaker for the purposes of tweaking passive crossovers? In theory it seems completely possible: I measure the tweeter first, then the woofer, and then do combined measures at different crossover points. Or am I better off using REW (not ideal because I prefer a device I can move around quickly) or something like Audio Tools? Thanks in advance.
Greg Wilding
Worth a try. I think the sub/main crossover measurement techniques can be applied to tweeter/woofer. The woofer will be fiddly to measure due to limited range. See subwoofer measurement, for a way around that. DM me if you have further questions.
TheOhGee
Thanks! Just realised it requires iOS 16.1 and above (dang it). I use an iPhone 6s that allows direct connection to my Dayton iMM-6 without a dongle flopping around, but it can't be upgraded beyond iOS 15.7. I'll have to keep looking for the right app... cheers for the reply in any case.
