REW Questions
RayDunzl
Central Scrutinizer
Riverview FL
@JohnPM
REW V5.20 Beta 13
Six sweeps, acoustic timing reference, the only setup difference is the sweep duration, using each of the available settings from 128k to 4M.
Frequency Response, as expected, overlaid nicely:
Impulse Response - what's going on here?
And Step:
Daverz
Because the measurements are different lengths, the IR delay is different for each measurement. I suggest aligning the impulse responses. On the Impulse tab click on Controls->Estimate IR Delay->Shift IR for each measurement before viewing in Overlays.
RayDunzl
RayDunzl
Central Scrutinizer
Riverview FL
I'm not looking at the time offset, although I might expect them to be the same, too.
I'm looking at the difference in the shape of the impulse and step,
"It seems like" in the past, using the different sweep times gave the same result.
I did do the "Estimate IR Delay", the waveshape remained unexpectedly ugly on the longer sweeps.
RayDunzl
RayDunzl
Central Scrutinizer
Riverview FL
Example:
Old sweeps, from August 2014, one with 256k, one with 1M length, with near perfect overlay:
REW V5.01 Beta 22
And a 256 and 1M sweep right now.
REW 5.20 Beta 13
Overlays don't match up. wondering why the shape, as well as the time, are different.
Krunok
Zg, Cro
Can you pls show overlayed phase responses in 5.20 Beta 13?
Daverz
I have beta 13 on my macbook. I'll try some measurements tomorrow.
RayDunzl
RayDunzl
Central Scrutinizer
Riverview FL
5.20 Beta 13
Red - 256k
Green - 1M sweep
Phase measures often give surprises.
Generally, I have come to expect to see "flat" from 200Hz up, due, I think, due to a lack of disturbing reflections in my setup. The jump around 200Hz (below) is likely the Crossover from panel to woofer is 180Hz.
The slope down at the higher frequencies is something new in newer versions.
Here's from five years ago:
Blue - 256k
Red - 1M - with a little surprise
Krunok
Zg, Cro
Have you tried measure them from a smaller distance, say 0.5m? That way you eliminate reflections and get a consistent curve.
Btw, in the one from 5 years ago both graphs are practically identical - those steps at HF are 360deg apart, not sure why they happened but they look benign. Not so good in this new version.
JohnPM
Do you have different devices for input and output? Looks like the sample rates are a little different to each other.
RayDunzl
RayDunzl
Central Scrutinizer
Riverview FL
I never listen from 0.5m, nor am I building speakers, and panels are a bit strange close up, so, no.
All my measures, unless noted otherwise, are from the listening position, at about 10 feet.
JohnPM
Blue - 256k
Phase wraps like that occur where there are nulls in the response from reflections, they show deviations from minimum phase behaviour. They can be a bit variable from measurement to measurement depending on whether the null is deep enough.
RayDunzl
RayDunzl
Central Scrutinizer
Riverview FL
In the newer measurement:
Using Java REW-> PC USB -> Topping D10 -> Optical -> switch -> DEQ2496 -> miniDSP OpenDRC-DI -> Benchmark DAC2 HGC for output,
UMIK-1 for input.
Also indicative of clock mismatch.
Well, there are plenty of chances for sample rate drift/change that in the string above.
Earlier measurements would likely have been:
Optical from the PC board -> switch -> DEQ2496 -> DAC2
Two ASRC there.
Thank you.
I'll experiment again.
JohnPM
It isn't sample rate conversion that is the problem, but the absolute accuracy of the clocks. See this thread for a similar issue.
Daverz
So you can't get an accurate impulse response with the UMIK-1 and a long sweep because of clock drift? Seems obvious in retrospect, but I'm out $90 for a measurement tool that's inadequate for the job.
I've been doing the longest measurements possible because of the DRC-FIR recommendation to use at least a 45 second sweep to reduce noise. The author does caution that "Using two different soundcards or a CD Player for reproduction and a soundcard for recording usually provides worse results unless they are accurately time synchronized", but I didn't want to deal with the extra cables and wall warts!
Krunok
Zg, Cro
Near field loudspeaker measurement is a very common thing when measuring speakers in a room. You can't measure phase correctly in a room from that distance because of reflections. Give it a try and you will see the difference.
JohnPM
No, that's not correct. I've seen a couple of examples where the clock appears to be slightly offset from 48 kHz, but all the UMIK samples I have tested (5 to date) have not shown any offset and have identical impulse responses at all sweep lengths.
Daverz
I'm using my music server to play back sweep files, so I was more worried about any errors introduced by drift between the clock in my DAC and the clock in the UMIK ADC.
edechamps
London, United Kingdom
@RayDunzl's impulse response measurements for various sweep lengths look quite different. Obviously, they can't all be correct at the same time. Most likely, all of them are wrong. It is worrying that REW would display incorrect impulse responses without warning the user that something might be off. Should REW attempt to detect clock drift and warn the user if it happens? Or better yet, should REW attempt to compensate for clock drift automatically (e.g. by resampling)?
dkfan9
Columbus, Ohio
Even for panels? I know a .5m panel measurement will give innaccurate FR--is phase immune to that issue? And .5m seems like it would create issues in many box speakers too, at least at crossover points.
