RME ADI-2/4 Pro SE - Auto-measured with Multitone
pkane
North-East
I don't know if this post is about the extremely nice, new RME ADI 2/4 Pro SE interface or about the new automated measurement capability of the Multitone app :)
Most of these measurements were done automatically using a Multitone test plan (I'll share in a separate post). This new feature allows a complete measurement script with multiple measurements to be executed, outputting the results ready for publication. More discussion of this script and the details will be posted later in the Multitone testing thread.
The only measurement that's was done the old-fashioned (manual) way is the filter frequency response.
Here are all the steps in the automated test plan:
I measured the DAC portion at 44.1k with ADC loopback at 44.1k. For the higher sample rate ADC captures (DAC filters) I used Cosmos ADC at 192k:
Here are the results:
Phase, Impulse Response
Last but not least is the actual test plan that contains all the settings to perform all of the above tests (except for the last filter response one).
  • ADI2-4 Pro SE.zip
Rja4000
Liège, Belgium
View attachment 274357View attachment 274358
View attachment 274360View attachment 274361
View attachment 274364. View attachment 274363View attachment 274365
Thanks!
I'll give it a try, to see if I'm able to reproduce those.
Also, I'll compare with measurements with my usual tools.
Are those measurements done in mono or stereo ?
morillon
with of course all the necessary precautions etc.
it is quite remarkable as an automatic procedure for us "amateurs"...
( the jtest is only for numeric mesureament..no?
pkane
pkane
North-East
Right! I’ve configured this test for my own set up, it was using WASAPI. ASiO may require changes or additional settings. With a different device, 0dBFS may be too high — in fact -1dBFS was recommended by RME, but I found that 0 works just fine. The Intersample over test required lowering the ADC gain as it was being saturated by the DAC, even though the DAC was handling the signal just fine.
While the same test plan may work fine for other devices, some small adjustments may still be needed .
morillon
intersample over...
it remains special as a test... enough to be afraid of most of the time...
(i don t see the "filter" on your plan)
morillon
ahhhh
if it is to promote rme products.... ;-)
(it remains a test...special...
and a consideration essentially of the professional world for the moment it seems to me ;-) )
pkane
pkane
North-East
ahhhh
Just an observation from the measurement, not my opinion.
Rja4000
Liège, Belgium
ahhhh
Well, if the music you want to reproduce contains such oversamples and you use a DAC that doesn't allow volume change and doesn't handle them well, that will be a consideration for you as well, I think.
Distortion may raise quite abruptly.
morillon
but it is conditions that I believe are mainly found in the studio, home studio , mastering etc.. right?
because the finished products for the public etc are normally "normalized".. and there is no real reason to come across this type of situation it seems to me...
pkane
pkane
North-East
Intersample overs exist in consumer music, not just in the studio. There are a number of threads on this subject here already. It’s enough of a problem to at least be curious how a DAC might handle these, but feel free to ignore that measurement if it doesn’t apply to you ;)
Trell
But handled easily by this new RME converter, so no need to be afraid :)
If that fact fails to convince there is always this litany from the classic Frank Herbert novel Dune. :)
I must not fear.
Fear is the mind-killer.
Fear is the little-death that brings total obliteration.
I will face my fear.
I will permit it to pass over me and through me.
And when it has gone past, I will turn the inner eye to see its path.
Where the fear has gone there will be nothing. Only I will remain.
morillon
links on this subject here .. or on commercialized productions posing problem?i⁷
I admit that I'm not a kid.. and I haven't really met any and digital clipping (not discreet..)
Above all, we must denounce if the work of standardization is badly done. and especially not let the thing settle..
the very, very large majority of general public DACs cannot manage it.. and that is the purpose)
pkane
pkane
North-East
What does this have to do with measuring how a DAC handles a specific test signal? Please post in the threads about intersample overs if you want to discuss that subject.
theREALdotnet
Thank you for these measurements! I’ve got two questions:
What is DIM? Some kind of intermodulation I gather, but I haven’t seen that acronym before.
The “THD vs Level” plot has me scratching my head. Wouldn’t the noise graph have to be a perfect complement of the distortion graph to make the THD+N such a straight line?
