RME ADI-2 DAC fs against the Topping D90SE
NiagaraPete
I had heard so much hype about the Topping D90SE I decided to buy it and compare against my RME ADI-2. Here is what I heard.
Caveats: Before I get started I wish to state I have no idea what the engineers were trying to attempt when they recorded the music I was listening to. All I can do is attempt to articulate what differences I heard between the two DAC’s and how they each exited my hearing. What I look for in a recording is my idea of a ‘true to life’ playback of I what I understand instruments and vocals should sound like in various spaces. My assessment is based around these 9 attributes:
  • Clarity/transparency of sound stage – separation of instruments and vocals and type of room I can image I am listening too (club, auditorium, outside venue, small room, large room etc). My guess as to what the engineer is attempting in the recording v what the DAC engineers and designers are doing with their chip sets and electronics.
  • Air in the clarity – muffling v top end articulation
  • Bottom end articulation
  • Mid-range articulation
  • Front to back imaging
  • Side to side imaging
  • Dynamics/attack
  • Scale – size of the performance in my room
  • Value for money
What I hear in my room (4.76m L x 3.74m W x 2.38m H) will be different to what others hear in theirs. My speakers sit about 1m from the short wall (3.74m) I sit 2.65m away from the front of the speakers and they are about 75cm from the side walls. It’s a small room! My hearing is still ok in the bottom frequencies but my top end stops at about 12k to 13k. I’m getting old!
Gear: Speakers – Revel Performa F228be, CD Transport – Cyrus XT SE + PSX-R, Amps – Pass XA25 and Bryston 4BSST 2, Cables - Mogami/Canare and my own, Interconnects – my own and Chord C-line. To give the XA25 more grunt I use the Burson Buffer Amp 160 (Class A Singled ended). I also used USB connection through my laptop using JRiver media. I don’t use pre-amps and rely on the pre-amp inside each unit.
Listening: I started my testing with the Pass XA25 then moved to the Bryston 4BSST 2 and quickly realized my testing is better off with the Pass + Burson buffer (the buffer provides more gain). The Pass is much more resolving, tonally more real and the imagery the best I have ever heard from any amp! The air and top end smoothness is something to be heard. Only drawback is it doesn’t put out enough watts to drive the Revels. They work extremely well with the horns I have built but that’s a review for another day. Don’t get me wrong, the Bryston is still a great amp and dynamics are superb with bottom end punch to leave you breathless and of course much more powerful than the Pass. But the Bryston’s top end has an edginess that doesn’t work with either of the D90SE or the ADI-2
Off the bat I can say that there is more energy and depth in bottom-end response in the D90SE than the ADI-2. The ADI-2 however had more energy and resolve in its top end. The D90SE provides an overarching sound of a smaller venue with little reverberation whereas the ADI-2 sounds more open in a more lively and larger venue. Therein lies the difference of the two units in my room!
The D90SE bass response is exciting without being bloated, it seems to garner another ½ octave. The ADI-2 is tighter and a little restrained in its lower registers. The ADI-2 shines with the air it brings to the top-end and the openness of instrumentation in staging.
The openness of the ADI-2 continues down to upper mids which brings out more detail in the human voice. The D90SE has less openness/air in its top-end but adds depth/density into the midrange over the ADI-2. Voices have less sibilance with the D90SE.
I found both to have similar side-to-side imaging but the ADI-2 had better front-to-back imaging. This I think came from the openness it brings to the party.
The ADI-2 clearly had more dynamics in its delivery. It seemed to work better and ‘louder’ with the XA25 + Burson Buffer. Not sure why? I had the D90SE on the 5v setting and I think the output of the ADI-2 reaches 3.46v at its maximum. The D90SE seemed to be ‘steady’ and the ADI-2 got more exited. Just like some people I know!
One interesting thing I noted was the D90SE seemed to present a bigger image on the staging, taller than the ADI-2. Both never seemed to faulter when driven hard but again a little more definition with the ADI-2.
When it comes to value for money (D90SE about $AUD 1300 and ADI-2 about $AUD $1700) I think both offer good value. I turned off the DSP/PEQ on the ADI-2 to compare DAC to DAC on an even playing field but this feature is remarkable and does help better integrate loudspeakers into rooms. The D90SE does allow greater connectivity for streaming and input functionality. The ADI-2 has two connections for headphones the D90SE has none. The ADI-2 is a complicated beast, it has a 69 page instruction booklet, the D90SE has a brochure and you are better off going to the web to find out how users use the device.
So what do I think? The ADI-2 still grabs me because it has the extra DSP/PEQ feature I enjoy and the air/openness and front-to-back localization of instruments/voices I crave in imaging. The D90SE is not far behind. If I could put the bass response and midrange warmth of the D90SE with the ADI-2 I don’t think there would be a DAC under $10,000 that could compete.
If you had done a comparison of features and specs it would’ve been helpful.
Willem
With such good measurements there is no way there can be sonic differences if tested under controlled conditions. If you want very good support, exceptional build quality and an extensive set of features, go for the ADI-2. If not, go for the cheaper Topping.
57gold
I'm sure it has been previously discussed, but some folks listen to gear and others to music.
Some trust their ears, and others the results of a few measurements.
By my little photo you may notice that I am a guitarist. In that world, there are folks that play music and others that spend most of their efforts on accumulating/collecting gear (guitars, amps, effects...). Some guys go on and on about tone, stacking multiple, expensive effects boxes in front of more expensive vintage or boutique amps that their favorite stars have been seen using...then they do a video demo to demonstrate tonal nirvana and can hardly play.
Different strokes.
I enjoy seeing the analytics posted here and discoveries made, like the power conditioners that add noise. Bought a demo Transparent power conditioner years ago based upon the hype of clean power and without double blind testing, determined that it changed the sound but didn't make it better, just different. It is now used as a power strip for our TV, cable box, Sonos, DVD player... Better sound with a decent power cable attached to the wall powering well-selected components.
All that said, when I need new gear I would check out the specs and tests here and elsewhere...then I would listen to how a new compenent sounds in my system.
