Room Measurement Tutorial for Dummies Part 2
OCA
Germany
Hi, I’m considering grabbing a UMIK1 but my receiver is another room in an equipment rack. Cable would probably need to be 50ft or longer. Any suggestions for setup in this scenario? I figure trying to use a really long hdmi cable is better than trying to use a long mic cable.
nathan
Keep in mind the UMIK1 does not use a mic cable at all. It uses USB. I would try running USB over Cat cable: USB Extender Over RJ45 Cat 6/5/5e Adapter, RJ45 Ethernet Splitter to USB Extension UP to 50m/164ft, Compatible with Computers, Mobile Phones, Mice, Keyboards, U Disks, Printers, Cameras since that is lower bandwidth than HDMI but: the good news is that you can use the absolutely cheapest extended HDMI solution too, I would guess, since all you are doing it sending audio and enough video to make the connection work.
stonith
until-
You should be able to get out to long lengths using a powered USB hub in the middle, or an active cable.
How long do you really need?
Active USB cables can go out to 90'
I've no idea how you figure to go from USB to HDMI and back again?
Forgot about active usb hubs. Thanks! The hdmi comment was regarding audio out to the receiver for the test tones.
192kbps
If Part 4 exists, why can't Part 3 come as soon as possible?;)
bdvan
Looks like Amir is busy, can someone with good REW experience post a pseudo-part 3 of this article.
DHzHolden
Room Measurement Tutorial for Dummies Part 2: Selecting a Measurement Microphone
...In the next tutorial we will get into the meat of these of lessons which is to actually perform the measurements and understand what they mean.
Hi! I loved Part 1, made Room Measurement with REW comprehensible for me. Part 2 ends on the cliffhanger above. where do I go from here? Seems that Part 3 never appeared, or maybe has a different title?
In any event, very helpful, thanks.
Dick
Sal1950
The Chicago Crusher
Central Fl
Dick
Hi Dick, welcome to ASR !
Wish I had some easier answers for you here. The original 2 chapters were written by Amir some years back and since he has
started this website I don't believe he has the time available any more to work on it.
Normally I would first refer you to the REW website but currently it doesn't seem to be online. I do hope it is a short term issue and will be back up shortly.
There is a very large community of user over at AVS forums with many experienced users willing to answer questions and help.
Sorry I don't have a more direct answer for you beyond this.
Sal1950
Robocop
Tauranga, New Zealand
I concur with Sal. There is no one source to get the perfect starter guide. It takes quite some effort/time to master. REW site is the first go to. You tube has some clips but all are not the complete story but worth watching. I personally found the Dutch and Dutch 8c method useful even though its integrated with REW https://dutchdutch.com/pages/rew-roommatching-guide. I adapted this to mine. Most info is on this ASR web site but takes some trawling to find. Its trial and error and eventually you should get to a satisfactory point. I do run a minidsp flex so have some support from them. It is worth it in the end and an interesting journey.
Robert
levimax
San Diego
Especially when starting out I have found it much easier and faster to use the MMM method. I have compared MMM results to multiple averaged measurements and I always get the same result. There are limitations to the analysis you can do but for in room FR measurements for room EQ it works well.
RayDunzl
Central Scrutinizer
Riverview FL
DHzHolden
Levi,
Thanks for linking this video, it was an eyeopener, not just for the moving-mic technique, but for further information about REW.
Dick
brass
London, UK
My promise to you in return is to give you the world's simplest and most foolproof way to perform room measurements. And do so in a manner that get gets you professional results with substantial ability to go as deep as you want.
...I guess it wasn't so simple...?!
levimax
San Diego
Trying to get useful measurements of a speaker in a room beyond nearfield is one of the hardest and most confusing things I have tried to learn about. I am currently working on putting together an "outside" measurement set up which I am sure will prove to be an adventure as well. Luckily just a hobby so all good fun.
Sal1950
The Chicago Crusher
Central Fl
