Room Treatment opinions and seeking Help with REW
Disruptor
Hello everyone, I want to ask for some help with my REW skills and im quite interested in your opinions!
First of all here is my room! (ye i know its kinda scuffed up and needs some paint and all that but that is not my priority right now ;))
The bed and the furniture on the sidewall will be gone soon but for now im stuck with this.
Those absorbers are DIY made of Rockwool 100cm x 60cm x 8cm
Skyline difusers are also DIY made to those specs
In total i have 15 made 6 of those are in a 3x2 array on the front wall and in a 3x3 on the back wall.
The rooms dimensions are: 370cm x 330cm x 254cm or 12ft x 11ft x 8ft
Speakers are set up at the long wall.
Speakers themselves are 135cm away from each other and are 30° tilted.
Gear:
JBL LSR 305 1. gen
JBL LSR 310 sub
Focusrite 2i2 1. gen
measuring mic: Sonarworks XREF 20
Those are my measurements 2 meters away from the front wall. (yes i know this is further than the isosceles triangle rule says but im still playing with the sitting distance and tilt) Ive measured various distances from 80cm to 200cm and found that 200cm is the best starting point.
Green line represents no EQ. 1/12 smoothing
Mic and Soundcard calibration files have been used.
After playing for quite some time with EQ´s and auto EQ´s from REW im still far away from my goals and this purple line feels like it lacks bass.
Ive just cut the peaks and didnt boost anything with the EQ that is applied here.
Since ive bought the Sonarworks mic i had a Sonarworks Reference trial and honestly i didn't fully like the results either.
Are there any tricks you guys could tell me and help me out or am i doomed with this sound curve^^
Would this freq curve be acceptable for you or are you disgusted with it?
Im also playing with the idea of buying a Genelec setup with 8351 and possibly two subs and just use their GLM system and be done but still i dont want to spend the money (around 12k €) and love to make the best of what i have now.
Krunok
Zg, Cro
Try cutting red circled region so it follows blue line. You would probably need 2 filters to do that:
1. 1800Hz, Q=2, gain= -5dB
2. 4500Hz, Q=3, gain -4dB
These are of course just orientation figures with which you should play untill you get it close to blue line.
You could also consider raising that dip at 65Hz to see if it will react. Something like 70Hz, Q=8, gain=8dB. If this doesn't help don't be tempted to use higher gain as it won't help but can screw amp/speakers.
pozz
Слава Україні
Editor
Hard to say form the pics, but it looks like you have your absorbers/diffusors mounted too high. I'm also not sure if your measurement from 2m away represents where you're actually sitting (that would be nearly 2/3 of the way into the room?).
So a few simple things would be to raise/tilt your monitors so that they fire more directly into your ears and lower your panels so that center around your ears.
When you measure, make sure you position the microphone at your sitting position, at ear height, measuring separately for R&L speakers and then averaging the results—you'll be able to see how differently the room affects each speaker. Use the variable smoothing function in REW as well to account for frequency-dependent psychoacoustic sensitivity.
The high frequency loss might be because your microphone either isn't positioned or calibrated correctly. It would be really unusual for your monitors to drop in response that fast.
Another thing you can try is to add a space between your Rockwool panels and the wall using brackets. Even a 3cm—4cm space will increase their effectiveness in the low mids/high bass. They are velocity-based absorbers, so having them directly against the wall isn't optimal.
D
Disruptor
for now ive played just a little bit but tomorrow ill report back in since i dont have any more time for the room
brown line is with the eq you recommended with a little tweaks
Krunok
Zg, Cro
It's getting better.
Try adding 3 more fitlers:
32Hz, Q=10, gain=-5dB
50Hz, Q=12, gain=-2dB
1500kHz, Q=3, gain=-3dB
Is your microphone aimed directly at speakers? You may try easing the 4500Hz filter as now it seems a bit too low.
pozz
Слава Україні
Editor
This purple line feels like it lacks bass.
Those 40Hz-ish and 60Hz-ish dips are room modes to do with the length of your walls and ceiling height. Treating those will be difficult.
D
Disruptor
yes the front wall is way to high but for now it is what it is and cannot be moved.
Yes mic height is of course considered and placed at my sitting position and ear level. Ive measured R&L and applied a little balance EQ since the right one plays 2,4db louder but never measured R&L for freq EQ purposes separate. And ill guess will read something about psychoacoustic sensitivity since ive seen it mentioned a few times
In the pic below the black line represents the mic calibration compensation. Could it be that my room takes up to much high freq?
Well they have about 2.5cm behind them and i know they only work in the mid/high freq band since they are way to thin
D
Disruptor
what ive forgot to mention is that the middle of the speakers aim at least at the lower third of the side and back panels
Krunok
Zg, Cro
[QUOTE="Disruptor, post: 227076, member: 1658"
[/QUOTE]
I think it is because mic is not pointed directly at the speakers. Does your convolution engine support separate left and right filters? It would be better to aim for those than for joint filter.
pozz
Слава Україні
Editor
No. Fabric-covered panels become reflective above 4kHz as far as I know. Calibration looks alright and in line with what I've looked up about your mic. It's definitely an issue with positioning—point the mic directly at each speaker from ear height to approximate what you're hearing most closely.
Beyond that, Room EQ isn't my thing—Krunok can give you much better advice there.
mitchco
@Krunok and @pozz have good suggestions. While there is no RT60 for a small room, it would be good to see in REW an overlay of both channels and clicking on the RT60 will give you a display of Topt (for small rooms). Set the frequency response display to cover 100 Hz to 10 kHz. This way we can tell how much absorption is in the room over this frequency range.
Ideally you want the mic pointing straight ahead like you have at ear height and at the listening position.
pozz
Слава Україні
Editor
Point the mic directly at each speaker from ear height to approximate what you're hearing most closely.
Seems like we're divergent on this point—what's the reasoning here @mitchco?
D
Disruptor
ive just tried pointing the mic at each speaker than averaging the two responses and its basically the same just 1-2db lower overall than having the mic dead straight pointing at the wall.
Im using Equalizer APO so i dont think it would be possible to have separate filters for each speaker
mitchco
I don't know the mic, but I presume it is a calibrated omnidirectional measurement mic. If so, then there should be little to no high frequency attenuation 30 degrees of axis. My measurement mic shows about a 2 dB droop in the top octave 90 degrees of axis...
Maybe I have not had enough coffee here in PST time zone and I am missing something...?
D
Disruptor
I hope this is what you meant
Krunok
Zg, Cro
Hard to tell from the pic but mic angle toward on-axis to the speakers may be more than 30deg.
It is calibrated mic.
