Lupin
- Joined
- Feb 11, 2021
- Messages
- 589
- Likes
- 981
I know, I know, the question has been asked a thousand times before but couldn't find an definitive answer for my situation.
I have a DAC (SMSL M200) of which the USB input is busted so I only have the optical or coax input available.
What is the best way to go?
1. Toslink out from my motherboard (Gigabyte X399 Aursus Gaming 7) to Toslink in on the SMSL M200
2. USB from computer to Singxer F-1 Audio Bridge and from there Coax to SMSL M200
I've tried to search a bit here and on DuckDuck but couldn't find much that relates to my situation as described above.
My common sense tells me that Toslink and Coax are both using the same S/PDIF protocol so there shouldn't be any difference there. But then there is the part of implementation..
Is the Singxer F-1 with it's own clock (audibly) better then whatever comes out of the Toslink connection straight from the motherboard?
Have the feeling that the Toslink out on the motherboard is more a "convenience" option rather something they spend time and money on to get it the best it can be.
Any recommendations?
