Sabaj A1 (2022) + Dac vs Loxjie A30?
Ttimms
I'm trying to decide between these two setups for a pair of Dali speakers. I am thinking of buying the Sabaj A1 which has tone controls and pairing it with my Arcam irDac (original 2013 model) or spending the extra £80 and going with the Loxjie A30 which is a Dac and amp. Which setup would be better?
antcollinet
UK/Cheshire
Here is the review of the A1 - I think the A30 is reviewed here also. Do you want quality sound? The reviews should tell you which alternative will get you closer…
Edit:
Here is the a30 review
T
Ttimms
Edit:
The review is of the old A1 model, not the 2022 model. I'm wondering if the Dac on the A30 would be better than the irDac which I own and if the A1 (2022) would be a good cheap option to go with for a desktop setup.
antcollinet
UK/Cheshire
Ah - sorry, try here instead:
